Steering 2004 XC70
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
goldxc70
Year and Model: XC70 2004
Has thanked: 27 times
Been thanked: 3 times
Re: Steering 2004 XC70
Post by goldxc70 »
chrism wrote: 30 Nov 2022, 14:42
jonesg wrote: 30 Nov 2022, 06:30 my front end tended to hunt on acceleration, it was worn control arms allowing torque steer..
My experience also.
Lifted car and looked for wear in suspension components. Nothing obvious found. Then used pry bar looking for play, again, nothing found.
chrism
Year and Model: S80 / 2005
Has thanked: 7 times
Been thanked: 78 times
Post by chrism »
If the control arms are snug could the subframe bushings were worn, allowing everything to shift together?
goldxc70
Post by goldxc70 »
chrism wrote: 02 Dec 2022, 13:32 If the control arms are snug could the subframe bushings were worn, allowing everything to shift together?
Didn't check those. I'll have a look tomorrow.
goldxc70
Post by goldxc70 »
goldxc70 wrote: 03 Dec 2022, 22:40
Subframe bushings are fine.
It's beginning to look like the rack.
What are the best options for replacement? OEM or rebuild?
Yikes - just looked up pricing :(
br0dy519
Year and Model: 2004 XC70
Has thanked: 126 times
Been thanked: 116 times
Post by br0dy519 »
Quality rebuilt all the way. Detroit axle or united power steering are good options. I paid about $300 CAD total last year for mine after I returned the core. There are rebuilders in Toronto that may or may not offer decent pricing.
Just be certain you get the right one. Variable or non variable assist. Threaded or push-in connections. ZF or SMI (CHECK the stamp on the pinion, I don't care what anybody says that's the only 100% accurate way of telling). And finally- The lower u-joint style. It's in your best interest to buy a new u-joint anyway so this may be done after purchasing the rack anyway (OEM from Volvo Toronto is a great price.)
04s60 2.4
04xc70 2.5t
Skymongrel
Year and Model: 2023 XC90, S80 2007
Has thanked: 19 times
Been thanked: 19 times
Post by Skymongrel »
Was gonna say control arm on the one side. Had something like that when braking, but makes sense could happen on acceleration.
goldxc70
Post by goldxc70 »
br0dy519 wrote: 06 Dec 2022, 20:37 Quality rebuilt all the way. Detroit axle or united power steering are good options. I paid about $300 CAD total last year for mine after I returned the core. There are rebuilders in Toronto that may or may not offer decent pricing.
Sounds like there is plenty of research to do. If I do decide to change the rack, I'll definitely change the hoses as well. The U-joint/steering shaft I changed last year to eliminate excess play.
goldxc70
Post by goldxc70 »
How about left side driveshaft? Could that be causing my "steering" problem?
