850r failing emissions miserably (HC and CO) Topic is solved
JayPea44
Year and Model: 2007 xc70
Has thanked: 36 times
Been thanked: 6 times
Post by JayPea44 »
I am in Sloans lake area, Edgewater area.
I've been trying to find a good diagram to check all the vacuum lines.
Has thanked: 2199 times
Been thanked: 1852 times
Did you check under the hood? Volvo used to have a sticker on the hood with the vacuum layout.
There are thumbnail pictures that you can expand on this thread from Volvo Forums website:
https://volvoforums.com/forum/volvo-850 ... ion-68636/
JayPea44
Post by JayPea44 »
scot850 wrote: 25 Jan 2023, 14:49 Did you check under the hood? Volvo used to have a sticker on the hood with the vacuum layout.
It is there, but a little small and torn up, thanks for the link!
Clemens
Has thanked: 498 times
Been thanked: 228 times
Post by Clemens »
One more thing: if you are not getting full boost, you might have a badly worn turbo, split intercooler hoses (check carefully, they might look okay if not boosting) or a shot intercooler.
Usually it's the hoses, but I had a badly worn turbo in my 94 and you could smell the overly rich exhaust gases when stomping on the loud pedal.
1996 855 R,
2010 V70 D5,
JayPea44
Post by JayPea44 »
Clemens wrote: 25 Jan 2023, 15:12 One more thing: if you are not getting full boost, you might have a badly worn turbo, split intercooler hoses (check carefully, they might look okay if not boosting) or a shot intercooler.
Thanks I'll check them out. I'm not too concerned right now unless it's causing or contributing to these issues. This old thing is a project so the turbo and associated system si going to get overhauled in the long run either way.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2856 times
Been thanked: 1332 times
Post by matthew1 »
They actually pulled the red/yellow/green/blue line one from MVS... I made (color coded) that probably 17 years ago :D
viewtopic.php?t=6941
Also -> Amazon link
JayPea44
Post by JayPea44 »
Perfect - I'll get out there tomorrow and go over these lines. Engine bay is a bit messy so I'm betting there's something lurking in there.
WhatAmIDoing
Has thanked: 104 times
Been thanked: 105 times
Post by WhatAmIDoing »
Just to add, If you don't know when your TCV was replaced, they are known to fail and cause erratic turbo behavior. Or any of those vacuum lines being split will reduce boost.
Has thanked: 1609 times
Been thanked: 4065 times
Note that red in Matt’s diagram doesn’t match the red on the Volvo diagram. Mark them with tape on your car before you pull them off
BlackBart
Has thanked: 967 times
Been thanked: 921 times
Post by BlackBart »
matthew1 wrote: 25 Jan 2023, 17:04 They actually pulled the red/yellow/green/blue line one from MVS... I made (color coded) that probably 17 years ago :D
You made that?! Funny, I used that, I have it printed in color in some folder somewhere! I even used colored hoses! (Makes it so much easier to see where you’re going)
JayPea - I also followed advice to tape and mark hoses first. It’s dark and hard to see and covered with grime back there.
I had some funny stumbling long ago, did a tuneup, thought I’d just look over the vac hoses....and they were dry, cracked, splitting. Ran perfectly with new hoses.
We had a cracked intercooler case once, and it stumbled and coughed and spewed black smoke and got single digit mileage while we limped it home. (We hit a big bag of onions in the dark that had fallen off a semi - no sh!t.)
