You are also forgetting the fill plug o-ring. Might also need a new fill plug as it can get stripped a little. Ensure to use exact torx bits, no looseness.
Remember to level with the correct fluid temp. The OBDII Bluetooth/Wi-Fi adapter for using a phone app doesn’t show the actual transmission temp. You need a good shop type scanner or VIDA.
Yet another transmission question - slipping
chitownV
- Year and Model: 2008 XC90 3.2
- Has thanked: 15 times
- Been thanked: 40 times
2008 XC90 3.2 AWD - 169k miles, Premium, Versatility 7 passenger, Climate, Convenience, retrofit Morimoto D2S HID bi-xenon, iPd swaybars & poly bushing inserts, Powerflex poly control arm bushings, Bilstein Touring Fr struts, Continental CrossContact LX25 255/55R18, Fr Infinity tweeters & speakers, hardwired cheap $17 Bluetooth to center console aux & pwr, CQuartz UK 3.0 ceramic coated, no oil consumption using Mobil 1 0W-40 even w/ my lead foot
BMWFan
- Year and Model: 2007 XC90
I'm going to change the transmission fluid this weekend. But first I wanted to make sure my VIDA software worked so I could reset the counter afterwards. The fill plug, o-ring and crush washer came in the kit.
I found out that the software runs, the USB interface gets a signal from the XC90 and has power, but the USB com status light only comes on for a second when I plug it into the laptop, then it goes out and I can't do any diagnostics. The last time I used this software and USB dongle was probably 3 years ago when the airbag light was on.
When the USB dongle is plugged into the laptop, it shows up in the Device Manager as a DICE device.
BMWFan
I guess I have to learn again how to use the VIDA software. I needed to turn on the car and then I could sorta read some data. But the USB light still didn't flash on the USB dongle.
It told me the oil quality sensor was red and I need to change the oil.
I clicked on the TCM but couldn't read the trans fluid temperature - it never went off the oil quality sensor.
I need to read up on how to use the software, I guess.
BMWFan
Got the fluid changed this weekend. It certainly shifts better overall, but I have to wait until warm weather for the real test. Once it gets into the 60s-70s or higher I'll be able to tell. This time when changing, I'm sure the level is set correctly and the oil counter was reset (that didn't happen the last time I changed it).
The old fluid was really dark. Almost black. It didn't smell burnt either.
chitownV
Sounds good. Keep us updated. You might also want to repeat the process 1k miles later since the old fluid was clearly dirty and broken down. There are still remnants of the old fluid in the transmission and who knows how much loose floating media/carbon is there.
Hi
Did you ever resolve this issue? I have a Volvo V70 D5 AWD -11 (built 2010) with the exact same symptoms. Runs and changes gears fine when cold but as soon as the gearbox fluid reaches 70⁰C (158⁰F) it starts to flare on every upshift. Not much but noticable. 50-200 rpms and then settles quiet and nicely into the next gear.
For me it was showing up after I changed fluid to new volvo original 3324/AW1 oil.
Start to think I got the wrong oil but Volvo says I should have this thin oil... So I dont know.
Car is built 2010 but MY2011. If it was a MY10 it should have 3309. Im starting to think I have the gen 1 of the gearbox anyway...
- 16 Replies
- 2214 Views
Last post by erikv11
- 1194 Views
Last post by mika
- 1959 Views
- 1141 Views
Last post by azureblue
- 1514 Views
Last post by Georgeandkira
