From water pump to SRS
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
azureblue
Year and Model: 2014 S60 T5
Has thanked: 16 times
Been thanked: 8 times
Re: From water pump to SRS
Post by azureblue »
I found the chattering relay - it's in the rear fuse / Relay panel, behind the LR tail light. The one on the very top row and the only one on the top row. Now to find out what that relay does, and if it's the relay or something controlling it..
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
jonesg
Year and Model: 2004 V70
Has thanked: 69 times
Been thanked: 481 times
Post by jonesg »
owners manual will show what the relay is for.
azureblue
Post by azureblue »
I swapped relays and it's not that one. When the turn signals behave, there is no noise coming from that relay. I think it's for the locking system. So now to find what controls that relay, that also affects the window motors, and the turn signals.
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
jonesg
Post by jonesg »
to answer that you need the circuit diagrams, google for it or use vida to see. try this, I don't know what yr it covers.
https://www.manualslib.com/manual/533732/Volvo-V70.html
Has thanked: 1507 times
Been thanked: 3824 times
azureblue wrote: 16 Apr 2023, 17:29 I found the chattering relay - it's in the rear fuse / Relay panel, behind the LR tail light. The one on the very top row and the only one on the top row. Now to find out what that relay does, and if it's the relay or something controlling it..
In front of the LR tail light, hopefully.
azureblue
Post by azureblue »
Yeah - from sitting inside the car perspective :-). It's not the relay itself, but something that controls it. I have a problem with the passenger door not locking - that microswitch, but I can't see how that would cause all of these other problems. I also checked my battery and its healthy and fully charges. I just wantt o find the problem before I get the SRS code reset..
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
jonesg
Post by jonesg »
it could be putting noise into the door security signal wire, confusing the ECM.
azureblue
Post by azureblue »
I'll read the schematic again - I missed the radio is also affected. I hear a relay click from behind the center console (radio and HVAC controls) and the radio comes on and the turn signals / windows work fine. the they don't. No pattern to it at all.
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
azureblue
Post by azureblue »
If I don't find it today, I will get a full code read tomorrow. Of course the car will work great as soon as it's plugged up..
544
122s
144 wagon
240
740T Wagon
850R Wagon
2002 V70 Wagon
2014 S60 T5
jonesg
Post by jonesg »
you can buy vida on a thumb drive for less then a scan.
https://diaglaptops.com/wp/vida2go/
