Hello friends
Unfortunately all 20 valves are bent.
702-A805-0866AE3A6971.jpeg[/attachment]
Here are some pictures .
Hope they will able to rebuild the engine head.
S80 - 2009 - 2.5 T - alternator belt torn - engine fails to ignite
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
That sucks. Hopefully the head can be salvaged.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
mtd240
- Year and Model: 2007 XC70
- Has thanked: 23 times
- Been thanked: 7 times
So the alternator belt snap caused the timing to jump - any idea what tore the alternator belt? Tensioner?
2007 XC70, white/oak, 175k miles
2008 XC70 3.2L, 115k miles
2016 XC60, osmium grey / off-black, 95k miles
Gone:
1990 240 DL Wagon, M47, lots of goodies. 372,000 miles
1978 242, lots and lots of work to get a reliable daily
1998 V70 XC, Almost done replacing everything, then I sold it
1996 850 NA, victim of sporadic tree falling. Protected the wife. RIP Volvo
Gone:
Have no idea if it was the tensioner or clutch . I replaced them both (a friend of mine , many years experience said that entire set should be replaced frequently .
I wonder why it should be this way , to cause so much demagogue because of belt torn?
The engine head was rebuilt , sounds good.
Currently problem is that alternator light comes up it is not charging . It seems like when connecting the blue wire to alternator it stopped charging . Changed the voltage regulator to a new original one (as previous did not charge at all). I wonder what could be the cause for it.
Also , my mech said he cannot rev above 3000. Changed now the plugs . Hope to get good news.
Hello,
Bad news.. cyl1 has low compression . All 4 have about 150 , and cyl1 has about 20-40 . So engine is not working smooth and still not rev above 3000.
Maybe the engine head/valves haven’t been done correctly so valves loosing compression?
Can it be due to camshaft position sensor/?
2 weeks now in the garage …
Any assistance will be appreciated .
- Krons
Has to either be bad piston rings or bad seal on the valves. Your mechanic should be able to determine which. If it have compression before I’d suspect the valves.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
- 1511 Views
- 1500 Views
Last post by pgill
- 1350 Views
Last post by Cees Klumper
- 2198 Views
Last post by ferocity02
- 1639 Views
Last post by erikv11
