2004 V70 2.4 Sudden pull to right after hitting bumps
SOURDOUGHJIM
- Year and Model: 2004 V70 2.4
- Has thanked: 55 times
- Been thanked: 28 times
I'll take the advice and replace lower control arms along with the ball joints. I have studied the Garthok, it has weaknesses. I will successfully gnarfle the Garthok.
SOURDOUGHJIM
Check out the old ball joint stud. No hex or torx. Couldn't tighten it or loosen it. One of the bolts did break off. Steering knuckle is at the machine shop getting that dealt with. On the bright side, pretty easy to r&r the control arm with the knuckle out of the way.
SOURDOUGHJIM
KidsV70, I'll check the tie rod end. That could be the issue that's making it drive squirrels. Thanks!
SOURDOUGHJIM
Squirrely... darned auto correct.
SOURDOUGHJIM
Right side is back together. Test drove and the issue seems to have been resolved. I didn't notice any sudden pull going over the bumps.
Pushing down the lower control arm was a bear. Ended up using the strut link mount as a pry point to push down the steering knuckle and put in the lower strut bolt. C-clamp brought the upper bolt hole in line.
Side note, when taking it apart, the axle bolt was loose. (CV shaft)
- jonesg
- Has thanked: 73 times
- Been thanked: 534 times
strongly suggest installing a new axle bolt to spec, mine departed after reusing it.
Pry bar with a short length of chain over the control arm is an easy way to pull it down. Loosen the control arm bolts to allow more freedom of movement.
or get this $15 OTC tool.
https://www.amazon.com/OTC-6007-Lower-C ... 138&sr=8-5
SOURDOUGHJIM
jonesg,
A new axle bolt was provided with the new ball joint. The video and suggestion of the chain is one of those, "why didn't I think of that" moments.
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
Yea getting those new control arms to cooperate is fun, prybar required. Shows how good the new rubber is vs the old stuff.
New suspension parts can really bring these old cars back to life.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
SOURDOUGHJIM
Update, after replacing the front control arms, ball joints, LH cv axle, LH hub and having it aligned, it rolls smoothly down the road. I would have replaced the RH hub had I thought about it earlier. P/S leak is fixed. Added the skid shield which was missing when I bought the car. I didn't want to put that on but thought it better than risking road debris holing my oil pan.
- 12 Replies
- 1816 Views
Last post by 2000c70hpt
- 2364 Views
Last post by ZionXIX
- 2293 Views
Last post by cn90
- 1006 Views
Last post by oragex
- 91 Replies
- 11202 Views
Last post by mrjay62
