Replacement interval for accessory and timing belt tensioner and pulleys?
Has thanked: 1611 times
Been thanked: 4072 times
Wizechatmgr showed me a great trick. Pack heavy grease around a “sealed pulley”, warm it with a torch and the grease flies in like magic
foggydogg
Has thanked: 83 times
Been thanked: 405 times
Post by foggydogg »
V50M66 wrote: 04 Jul 2023, 23:09 My serpentine belt tensioner was absolutely cooked at 170k. I'd do it. Not worth risking the engine over a hundred bucks or so.
Doing just the timing belt is a HORRIBLE idea. Do it once, do it right. If it's coming that far apart, why cheap out?
He mentioned above that he will change all the timing components, it is the accessory belt tensioner under discussion here.
I agree with Dr. Abscate on this matter, change the belt and leave the tensioner alone unless it feels wonky on inspection. My '00XC has its original serpentine pulley hardware on it at 325k.
FireFox31
Has thanked: 159 times
Been thanked: 303 times
Post by FireFox31 »
Thanks for all of the advice. I will pull the belt, move the accessory tensioner to see how it feels, and spin its pulley to check for free movement. Should I expect the bearing to have a stiff drag to indicate health, while freely spinning indicates wear? The pulley is easily available for around $30.
V50M66 wrote: 04 Jul 2023, 23:09 If it's coming that far apart, why cheap out?
This is a great point. When doing timing, I will already have the coolant tank and more removed to give me access to the belt area, and be on the lift, set up, and ready to work. Do I want to do that preparation a second time to replace the accessory belt hardware when it fails? Proactive replacement can save that repeated use of time if the price is reasonable (which it's not with my double-priced tensioner).
It's easy enough to check the tensioner and its pulley so I'll do that. Might proactively replace the pulley as a compromise and inexpensive investment in not repeating the work.
FireFox31
Has thanked: 312 times
Been thanked: 818 times
Post by erikv11 »
Freely spinning indicates the pulley is dry (no or minimal grease inside), doesn't tell you much by itself about bearing wear though if it's been run dry a long time the bearings are likely more worn. Healthy pulley has some drag yes.
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
No Volvo specific experience here, but on my truck I don't replace them by a schedule. I just check them by hand when the occasion arises. I had one that was short lived, and I've had one that went almost 300K miles. The short lived pulley started making noise as it ate the brass bushing up.... new one has a ball bearing. The ~300K mile pulley just had a notchy feel to it when spun by hand, no real slop.
The belt gets replaced when it starts getting cracked and I feel like doing it.... never had one break.
I do need to take an up close look at the belt on my S70.... my first time for a two sided belt. I did replace the serpentine belt on the 850 when I did the timing set, but kept the rest of the system.
If the serpentine belt fails, the nice thing is that you don't lose the water pump, like my truck would. The engine could safely continue to run until the battery gets too weak. Steering shouldn't be too bad while rolling.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Krons
Year and Model: 08S60 05XC90 02S60
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
Just did it on my kids 02 at 187k miles. Could bearing have went longer? Maybe but it felt rough and seemed silly to not change for $8.
08 C702.5T (sold)
The non-Swedes:
V50M66
Year and Model: 1998 V70 AWD
Has thanked: 26 times
Been thanked: 94 times
Post by V50M66 »
454cid wrote: 05 Jul 2023, 13:09 No Volvo specific experience here, but on my truck I don't replace them by a schedule. I just check them by hand when the occasion arises. I had one that was short lived, and I've had one that went almost 300K miles. The short lived pulley started making noise as it ate the brass bushing up.... new one has a ball bearing. The ~300K mile pulley just had a notchy feel to it when spun by hand, no real slop.
Problem is, more often than not the serpentine belt will get sucked into the timing belt on these engines and grenade the entire motor. Which is why serpentine belt replacement is almost as important as timing belt replacement on these
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
FireFox31
Post by FireFox31 »
V50M66 wrote: 05 Jul 2023, 22:03 Problem is, more often than not the serpentine belt will get sucked into the timing belt on these engines and grenade the entire motor. Which is why serpentine belt replacement is almost as important as timing belt replacement on these
That's a solid tip, thanks. I bought a new accessory belt tensioner pulley and will check the existing equipment to determine if I replace the whole tensioner or just the pulley. The belt will be replaced, of course.
Darn, $8 for a P2 tensioner pulley. The P80 INA one cost $30. Still cheaper than a ruined engine from belt failure.
FireFox31
V50M66
Post by V50M66 »
You’re already in there, and I’d much rather spend another hundred bucks on stuff that won’t even take much more time to put in if it means not potentially spending thousands for a new engine down the road
That’s a BMW thing, serp belt wiping out the timing belt. It doesn’t apply on the P80 and P2 platforms unless you are really unkarmic
