I understand, though like I said, I might need a new valve body OR new transmission. It really depends on what has broken and if my clutch packs are worn.
There is also one other question I am very eager to know the answer to. What happens if Semi-synthetic and Synthetic fluids are mixed. I was running a mix of Mobil, Ravenol and Aisin Warner.
Alternate tranny fluid for 2002 S60?
chrism
- Year and Model: S80 / 2005
- Has thanked: 7 times
- Been thanked: 89 times
I’ve been running Mobil 3309 in my 2003 V70 for the last 100,000+ miles with absolutely no ill effects. No other additives. Currently have just over 250,000 miles on the car and it still shifts like new. (Keeping my fingers crossed)Blacklab467 wrote: 20 Aug 2023, 18:46 You're looking for 3309 spec. Mobil makes it as do most other oil providers, Toyota would be able to sell you something that satisfies that spec at the dealership parts counter, also probably Nissan if you're in a bind.
- 02V70
- Year and Model: 2002 V70XC
- Has thanked: 53 times
- Been thanked: 40 times
vtl, did you have problems with Mobil 3309? It says here that it contains the friction modifiers. My transmission has no problems, and I'm just doing a drain and refill since the fluid is dark. Im not sure whether to get the mobil or volvo fluid.
2002 v70 X/C 288k miles
- 02V70
Was that because your transmission had problems, or the fluid? I live in the magical land of California with 100-degree summers and 10-degree snowy winters, so I'll probably end up getting the Volvo fluid.
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
I think, fluid. Valve body has been replaced with Sonnax, it worked fine after drain&fill with Volvo fluid.
Also I put in a rebuilt transmission with a brand new valve body, I had shift concerns with Toyota T-IV, which is very similar to Mobil 3309. No problems with Volvo fluid.
dikidera
- Year and Model: S60 2005
- Has thanked: 68 times
- Been thanked: 187 times
On the topic, how do we do a full flush? Drain from drain plug as much as we can, then can we start the car and drain again, or maybe drain again via the cooler return line?
I have very contaminated oil with coolant, I already did almost 5 liters of fresh fluid, but it's not really clearing up. I have 6 more liters and would like to really get the old fluid out. I mean, the gearbox could be dead, there was black sludge on the drain plug(sludge, paste whatever you want to call it). It was a hefty amount. It could be dead, but worth a try to really clean it up.
This is why I went with Mannol JWS3309 and if the gearbox actually comes back to life, I could probably try some Volvo fluid for the modifiers.
- 02V70
How does coolant get in the transmission? Im not sure about transmissions, but my engine survived having a bunch of coolant in the oil. This link may help for flushing: https://www.matthewsvolvosite.com/new-m ... -pictures/. Maybe you could try flushing multiple times with cheap fluid.
- 697 Views
Last post by brando_calrissian
- 27 Replies
- 7771 Views
Last post by Blockpartie
- 926 Views
Last post by Sommerfeldt
- 14 Replies
- 3768 Views
Last post by alfatango1
- 502 Views
