My 1999 T5 S70 has developed the dash rattle/squeak again. Had it pulled and fixed several years ago. I have yet to pull the dash cover to assess the damage. I assume since is was repaired once, my current dash may/could be damaged beyond repair. If it is then I am thinking of other options. I have called several salvage yards and only one has a clean dash to purchase. The one yard that does wants $300 for it. I am in Dallas if anyone know of anyone who has a reasonably priced dash.
My car has 160+K miles. Car is in above average shape. Runs and drives as it should. I commute to and from work (25 miles round trip). Just put new tires on it, both 02 sensors, axle, control arm, front brakes and stage 0 in the last month. I plan to keep at least another year and then give it to my nephew as his first car for HS.
I did some research on fixes.... found brackets, shims, spray foam from engine side of firewall and things of the sort. What I am wondering, and I know it is not the best option, but could one pull the dash pad and use spray foam in strategic places to support the dash without removing it? I would think access with the gauge cluster, radio, glove box, and cover off the dash you could gain access to the majority of the dash?
I would be happy document my attempt to fix if someone has an alternative fix. Any thoughts?
Dash rattle. Questions regarding alternate fix.
- rspi
- Has thanked: 34 times
- Been thanked: 72 times
Contact rspi..
There are usually several of the x70 cars in the Pull and Pay's there in the Dallas area. I can't imagine any of them costing more than $60. I'll be there in a few days if you'd like a little help.
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
Blandis:
My previous dash top has been sitting indoors in a box in my house for years. Got a new one when I upgraded to the DPL stereo system. I'm down South near Austin. Not sure if 99's share the same top as 98's. PM me if interested.
I've used silicone grease, self-adhesive felt & foam tapes, hot glue, caulk, etc. to silence parts rubbing on something else.
M1 10W-30 HM
M1 10W-30 HM
mecheng
- Has thanked: 15 times
- Been thanked: 21 times
Shove some rubber between the dash and the body, cured 90% of the squeaks for me. I put them where I noticed the squeaking.
1997 Volvo 850 GLT - 190km
Boost is my drug of choice
- Has thanked: 311 times
- Been thanked: 817 times
Just to clarify (check the OP, it is very clear): blandis is looking for a locally sourced dashboard, not a dash pad/cover/top. The dash itself is a very different beast from the dash pad.sleddriver wrote:Blandis:
My previous dash top has been sitting indoors in a box in my house for years. Got a new one when I upgraded to the DPL stereo system. I'm down South near Austin. Not sure if 99's share the same top as 98's. PM me if interested. ...
In my experience the junkyards are often much less than helpful on the phone, compared to when you are there and have removed a part etc. Anyway $300 for a dash from the yard is absurd. At the U-pull I've been to the most, they are currently going for $51 (http://upullrparts.com/prices?catID=13)
- sleddriver
Erikv11: Point taken. My mistake.
Replacing the entire dashboard sounds like a LOT of work. Sure glad mine isn't loose or squeaking.
M1 10W-30 HM
M1 10W-30 HM
blandis
- Year and Model: 99 S70 T5
- Been thanked: 3 times
Sled appreciate you offering. I need the actual dash unit, not the cover. Removing the dash is not that bad of a job. My concern is that since it was repaired once, that a second repair may not be feasible/possible. I found one yard that has two cars (pick and pull scenario) and both places are under $70 for the dash assembly. May go next weekend and check them out.
Brad
Nashua, NH
2017 XC60 AWD
2006 XC90 2.5T
Nashua, NH
2017 XC60 AWD
2006 XC90 2.5T
speedyt5
- Year and Model: s70 t5, 1999
- Been thanked: 2 times
I was just at the yard here in Austin, at least 5 or 6 70 model cars, one of them was in really great shape and as of last week the whole dash was in it. I did this job myself, it is very easy, you just need patience and a hand to get the new dash inside. Have you tried tightening the 4 bolts at the firewall first? Sometimes they just get loose and need a tightening, if they keep spinning and don't tighten, your dash mounts are done, if they can tighten then you should reduce a significant amount of rattle. There is something else as well; there are two bolts on each side of lower dash near the footwells, you remove the plastic cover for the trim that goes over the carpet, you can try pushing up and down on the dash while tightening the bolts and sometimes that can help as well. I can give you more help if you want through text or pm. Let me know if you need any help, I have done this job two different times.
As for the foam, there is a shop that uses a loaner car her in Austin and they foamed the dash, it seems to have worked but I can still hear rattles while I am in that car.
RSPI, are you making it to Austin at all, or just Dallas?
blandis
Completed dash repair on Monday. Followed Roberts youtube video which really covers almost everything. Only issue I had is the center bolt (goes through the firewall) on the passanger side would not line up. Pulled it twice to try to address... dash sits to high. Gave up and moved on.
Installed new ignition while I had it apart as it was due. Key started acting up a week ago or so.
No squeeks or rattles. Will be anxious to see how long this holds up.
Brad
Nashua, NH
2017 XC60 AWD
2006 XC90 2.5T
Nashua, NH
2017 XC60 AWD
2006 XC90 2.5T
- 603 Views
Last post by mrbrian200
- 2313 Views
Last post by TheMrFailz
- 3459 Views
- 358 Views
Last post by TJsPOV
- 681 Views
Last post by brando_calrissian
