Bad shifting after transmission fluid flush
FireFox31
Has thanked: 159 times
Been thanked: 303 times
Post by FireFox31 »
Thanks for sharing that you reset the adaprion and it worked well. For my terrible G70 transmission, I will plan to reset them immediately after the flush. I hope that will help the torque converter which may be constantly locking and unlocking while coasting.
FireFox31
V50M66
Year and Model: 1998 V70 AWD
Has thanked: 26 times
Been thanked: 94 times
Post by V50M66 »
FireFox31 wrote: 25 Aug 2023, 22:12 Thanks for sharing that you reset the adaprion and it worked well. For my terrible G70 transmission, I will plan to reset them immediately after the flush. I hope that will help the torque converter which may be constantly locking and unlocking while coasting.
I should clarify that it worked well after internal repairs on my ‘04 XC. Not exactly apples to apples, but it’s pretty similar from a software standpoint so it should still be ok.
Mine does that too (unlocking off the gas, then re-locking on the gas), but otherwise seems perfectly fine. Not sure if that’s just how these old 4 speeds are.
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
1999 Saab 9-3 - daily
2004 XC70 - former workhorse, parted
2005 V50 T5 M66 FWD - former garage queen, sold
2002 S40 1.9T - former daily, rear ended
Has thanked: 1611 times
Been thanked: 4075 times
I’ve observed this on my AT 1999s with DENSO, the torque converter doesn’t unlock on coast, but the minute you reapply torque, it unlocks briefly , then locks again, as shown by the tach
I think this is normal, but my Venn diagram overlap with normal is rather small.
Doferr
Year and Model: 2010 XC60 T6
Post by Doferr »
I’m experiencing a similar issue. After three drain and fill cycles, my transmission has a rough shift between the second and third gears. However, I’ve noticed that this problem only occurs when the car hasn’t warmed up yet. Once the car reaches its normal operating temperature, the shifting seems to return to normal. Last night, I reset the fluid counter, which may have worsened the problem. I’m considering resetting the adaptations, but based on my research, this is only recommended for transmissions that have been repaired. What are the risks of resetting adaptations in my situation? Could it lead to damage?
