I'll have to write a TC logger. My canbus is already spammed enough haha. What do you think of Lubeguard instant shudder fix?
I can't be certain of the shudder in 5th gear, I really can't, but 3rd gear (shifter in position marked '3') in specific RPM/speed oh yeah definitely.
Bummer abount sonnax, but let's not forget that bores in valvebody can and do wear out. Once out of spec, nothing will be correct. New is new, but also expensive.
What are the differences between these transmissions?
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
I use Lubegard HFM to prolong ATF life and reduce stress on frictions. Volvo likes its transmissions to slip for a bit of extra comfort.
Sonnax re-bores valve bodies and uses bigger plungers with O-rings to seal better. However they don't re-bore everything, so Sonnax VB is still not new. It is also labor intensive and costs a lot in US where labor is very expensive. Can not match GM VB price or around $500, not at all.
- 19 Replies
- 3374 Views
Last post by 850TurboTurtle
- 1833 Views
Last post by jimmy57
- 2440 Views
Last post by jmorman
- 1377 Views
Last post by TheYoungSir
- 2043 Views
Last post by dmg4
