2009 Volvo S70 Wheels
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Re: 2009 Volvo S70 Wheels
Post by MoVolvos »
V50M66 wrote: 30 Nov 2023, 09:46
MoVolvos wrote: 29 Nov 2023, 22:17
V50M66 wrote: 22 Nov 2023, 22:17 Yes, P2 wheels fit just fine. Here’s my ‘98 on 17” Neptunes (off an XC90):
I do have a crap but round and airtight set of 15” Naiads that I’d let go for next to nothing if you’re in the Northeast or upper Midwest
What's the tire size?
215/45R17 on the Neptunes, 205/65R15 (corded, with 2002 date codes) on the Naiads (they're off an XC).
Have you ever tried 225's on the P80. Am considering 225/45/17 with Orpheus which is the OE sizing for the 07 S60 which I have already.
V50M66
Year and Model: 1998 V70 AWD
Has thanked: 26 times
Been thanked: 89 times
Post by V50M66 »
MoVolvos wrote: 30 Nov 2023, 11:13
I have not. From what I've read they'll rub
1998 V70 AWD - Emerald Green/Tan - M56/Delta link swap, VAST tuned, lots of fun
1998 V70 NA - Nautic Blue/Charcoal - Factory M56/slicktop track car
2006 XC70 Ocean Race - workhorse
2002 S40 1.9T - daily
2004 XC70 - Mystic Silver/Black - former workhorse, parted
2005 V50 T5 M66 FWD - Black Stone/Black leather - former garage queen, sold
Has thanked: 1850 times
Been thanked: 1712 times
I run 225/45/17 on my car but it is an AWD. The main difference is at the rear as the FWD parking brake goes into the hub on an angle where the AWD goes in perpendicularly. On full extension it is possible that the wheel will bind at full suspension extension. At the front, I used to have no issues until the dealer replaced the front sub-frame bushes. The tire now rubs on the LHS inner fender where it didn't before. RHS is fine.
If you can find a 17" wheel with say a 40-43mm offset it may work but I still think there may be an issue at the rear parking brake cables.
Only way to be sure is to check the current offset of your rims, then measure the gap from the closest point to a rub point at the back.
Then adjust for a different offset (larger offset moves the tire inwards), and then add half the different tire width. Obviously, using the same offset as original (43mm and assuming you are using that now) you only need to add half the tire width.
MoVolvos
Post by MoVolvos »
V50M66 wrote: 30 Nov 2023, 12:27
Yes, I just read that today also. Thanks.
MoVolvos
Post by MoVolvos »
MoVolvos wrote: 03 Dec 2023, 21:07
Yes, I just read that again today. 2 Volvos needing tires with 5 sets of rims to choose, 15, 16, (2) 17 and 18 :? thanks.
MoVolvos
Post by MoVolvos »
scot850 wrote: 30 Nov 2023, 13:18 I run 225/45/17 on my car but it is an AWD. The main difference is at the rear as the FWD parking brake goes into the hub on an angle where the AWD goes in perpendicularly. On full extension it is possible that the wheel will bind at full suspension extension. At the front, I used to have no issues until the dealer replaced the front sub-frame bushes. The tire now rubs on the LHS inner fender where it didn't before. RHS is fine.
Have 5 sets of rims currently for the 00 S70 and 07 S60. The 15 is 43mm, 16 is 49mm, (2) 17 are 49mm as is with the 18. Was thinking of the 225/45/17 on the 07 S60 and in case I don't like the ride perhaps it can go to the 00 S70. I can then go with a 235/45/17 or 225/45/18 on the 07 S60. Will see how the current new 205/55/16 Goodyears work out on the 00 S70. It's a little big but can be used on the 07 S60 as the rims are from it.
MoVolvos
Post by MoVolvos »
Should start another post as the OP was done quite sometime ago.
vadapaavoo
Year and Model: 2122
Post by vadapaavoo »
I am running P2 Volvo rims on my 00 V70R. P2 wheels are the same lug bolt pitch and hub diameter. indigocard activate
roblox exploit
MoVolvos
Post by MoVolvos »
vadapaavoo wrote: 04 Dec 2023, 09:08 I am running P2 Volvo rims on my 00 V70R. P2 wheels are the same lug bolt pitch and hub diameter.
These are my go to links for fitment reference. Should still check with the tire dealer if going Plus 1 or Plus 2.
https://tiresize.com/comparison/
https://www.wheel-size.com/size/
https://www.wheel-size.com/calc/
https://m.roadkillcustoms.com/tire-widt ... eel-width/
tjmartin317
Year and Model: 2000 S70
Been thanked: 6 times
Post by tjmartin317 »
MoVolvos wrote: 03 Dec 2023, 21:24 .
OP has just been to busy to engage. But to answer the question that was already answered, tires are 205/55/16… don’t seem to be rubbing or causing any issues, and loving them so far!
2012 Acura TSX Wagon (Iris - Practical Daily)
2000 Volvo S70 (Blue - Manual Beater)
1972 VW Type 3 Squareback (Fargo - Terrible Rustbucket)
