S70 t5 1998 Aftermarket central locking
xanthefin
Year and Model: 1997 850
Has thanked: 106 times
Been thanked: 130 times
Post by xanthefin »
BEJinFbk wrote: 25 Mar 2024, 21:29
Just going a completely different direction.
Am I right that you still have a key and a fob?
And is that key chipped? In your part of the
world, I don't know which system you have.
In some countries, a '98 is a US MY '99.
If you considering chip in the key for immo. USA export models got chipped keys (and immo) very late with 99 years models.
EU models had chipped keys ever since 95-96 models.
befarrer
Year and Model: 1998 V70 AWD
Has thanked: 1 time
Been thanked: 24 times
Post by befarrer »
I just installed remote start with keyless entry into my 98 V70, I have no original Volvo fobs, no chipped key. On the driver's side door key tumbler are 2 wires, this sends the lock/unlock/disarm signal to the immobilizer module. How the lock works is if you turn the key in the driver's door once, only the driver's door opens, if you turn it again, all of the doors open. When you use the key to lock, all of the doors lock.
You need to tap into these wires, they are seperate from the lock and unlock switch on the door. To unlock, you need a double pulse signal, I think the first pulse disarms the alarm, the second unlocks. If you send a signal down the lock wire, it locks and arms the alarm after a timer countdown.
For me to remote start my car, I have to unlock with my fob, then lock my car, then remote start. Otherwise the alarm goes off. I want to try to get it to send a signal down my unlock wire before starting to turn off alarm automatically.
98 V70 GLT AWD
05 VW Golf TDI
93 Mazda B2200 with 13B rotary engine swap
Has thanked: 2212 times
Been thanked: 1853 times
There is a bypass, usually aftermarket, that the remote start guys have to install for both automatic and manual trans, even with the shipless units.
