The virtue of the Pentosin is that it has an extremely low pour point for extreme cold weather use. Volvo, Audi, etc. spec it so they can just fill one fluid and ship cars anywhere. The downside is that it is thin, has a lot more additives in it (that do not lubricate), and it causes faster wear, and you pay a stif premium for that reduced performance. One of the first things those of us in the good old Audi days (‘90s and forward) did was dump it and put in Dex III. Cheaper and in fact better fluid if you are not near the Arctic circle.scot850 wrote: 02 Jul 2024, 15:56 Turns out that the 202 is compatible with the olde CF11S. My mechanic buddy sent me a note on it. So I already have a liter I bought by 'accident' of 202 recently. So that will work just fine. Also Volvo of Toronto are not allowed to ship fluids like this so I would be at the mercy of the local dealer pricing.............!!
If you are having leaks, consider using Lubegard ATF (pricey), or use some of their AT additive or PSF additive. THe ester oil base will repair seals, and it will also increase thermal transfer and lower temps slightly. Both good things.
