They won't work on pre-2007 cars? That means they work on a 2008-9 S60 which is basically the same car??
My local dealer works on any Volvo that comes in. Volvo also have a tow in program that is free if the dealer repairs the car, no matter the age of Volvo.
Intermittent non start issue, ign switch or cem?
- Has thanked: 2196 times
- Been thanked: 1850 times
GeoffPetersen
- Year and Model: 2005 v70
- Been thanked: 2 times
Indie shop doesn't want to work on it either. Thinks it'd be wasting money because the leaking main seal is a ticking time bomb that's gonna ruin the timing belt and wreck the motor and to fix that is worth more than the car and so fixing anything else is just throwing money down the drain. I appreciate the honesty, but I'm not sending Geoff to the scrapper yet when he's got plenty of life in him. Wife can drive the Chevy, I only have a few miles commute.
- Been thanked: 4063 times
A VIDA setup might be in your future for Geoff. The P2 cars have good diagnostics since they are full bore CANBUS cars unlike the last generation. The 2005 is also the second generation, more reliable CANBUS model.
Maybe there is a MVS member in Asheville area, too?
GeoffPetersen
Went ahead and swapped the PEM. Old one looked pretty crusty. Fingers crossed
GeoffPetersen
After a couple days with new PEM, no problems. No CEL, no codes so far. Does take a few more cranks before it fires. But has been consistently starting.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
vida should sort that out, it can test the pem and read out fuel pressure.GeoffPetersen wrote: 04 Sep 2024, 23:40 After a couple days with new PEM, no problems. No CEL, no codes so far. Does take a few more cranks before it fires. But has been consistently starting.
kinda sounds llike its losing pressure between use.
GeoffPetersen
Well after a couple good weeks we're back to the same old tricks. I'm convinced it's the immobilizer now since I did get a " start prevented" message on one try when the message board was actually working. It had been doing ok after a couple tries but it's getting worse, taking more and more tries before I get it to go. I spent 40 minutes this afternoon fighting with it before giving up and getting a ride home. Guess I'll take a look at the antenna ring, clean the contacts and all that. But it'll probably start on the first crank tomorrow
It can also be your transmitter chip in the key that is failing. Try the antenna ring. Careful removing it as it is fragile at this age. Look around it for sings of cracking. I had one that was cracked right through it.
Cleaning the contacts with electrical cleaner to remove oxide build up is also worth trying.
- 3478 Views
Last post by reeltapegone
- 35 Replies
- 13597 Views
Last post by goldmandan
- 8577 Views
- 27 Replies
- 27262 Views
Last post by cn90
- 9971 Views
Last post by jonesg
