Update:
Replaced all vacuum line fittings. Cleaned MAF. Checked for exhaust leaks (non). Just got back from another failed emissions test with the NO ppm well into the gross polluter category. Any ideas? Appreciate any suggestions. Contemplating a visit to an independent Volvo mechanic as I am out of ideas.
‘97 850na Wagon failed smog test
SlowandSteady
- Year and Model: 1997 850
- Has thanked: 1 time
Nox high is a lean running condition. It is usually vacuum leaks that cause this, and smoke testing is the quick way to tHat out
SlowandSteady
Replaced all of the vacuum lines and the MAF with another Bosch unit that I sourced from a 97 at a scrapyard. Retest had my Nox drop significantly lower than the legal limit but my hydrocarbon numbers were now above of the legal limit…next I treated the fuel with some sea foam and replaced spark plugs….next retest both my Nox and HC numbers were well above legal limit. Any tips greatly appreciated.
- 14 Replies
- 3233 Views
- 1024 Views
- 6044 Views
Last post by erikv11
- 5178 Views
- 1054 Views
Last post by Paul-93-850
