2006 S60 2.5T AWD: cam/crank seal tools?
Antoine240bk
Year and Model: XC70 2.5T-2006 - 4C
Has thanked: 12 times
Been thanked: 30 times
Post by Antoine240bk »
Hi, i just completed this exact job two days ago. I found out that the crankshaft seal was leaking.
The tool 9995455 for the crankshaft seal made the installation easier, the inside spring on the seal is already in place on the tool.
As i did not used the crank locking tool i had to take care not moving the crank. If you remove the oil pump do the seal then.
Last year i did the internal seals, paper & O-ring
For the rear cams i used the tool 9995450, you screw the seal with the tool and done!
I did this after installing the belt so no worries about moving the cams.
Lots of pictures here Page 9 & 10 , sorry it is in french but you will have a good view
http://univers-volvo.fr/showthread.php? ... 97&page=10
Volvo XC70 2.5 T AWD P2 B5254T2 - 12/2005 Four-C Previous : Volvo V70 P1 2.4l 20s 170ch B5244S 03/2000 - Volvo 245 GL Break 1979 B21 -LPG - Volvo 240 GL Break 04/1992 B230F (Daily for 14 years)
