Many thanks, but it is for the 06 XC70 that is my son's, and not the S60 I worked on on the weekend. But they should be the same. I am in a monitoring mode on this just now. Not sure if or what is leaking if anything. I had been planning a coolant flush in the fall here, so to swap it out, this would be the time if there is an issue.
Appreciate the link!!
Heater core replacement - Brands? - 06 XC70
- Has thanked: 2215 times
- Been thanked: 1853 times
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Pinch the hoses from engine compartment, twist and pull to remove. They will be seized most likely, so it helps to wiggle/rotate them a few times beforehand. Place a quart container under one of the metal pipes going through firewall and blow compressed air in another: you'll get your old core and piping free of coolant almost entirely. Air compressor or shop vac in reverse both work equally well.scot850 wrote: 01 Oct 2024, 10:42 Many thanks, but it is for the 06 XC70 that is my son's, and not the S60 I worked on on the weekend. But they should be the same. I am in a monitoring mode on this just now. Not sure if or what is leaking if anything. I had been planning a coolant flush in the fall here, so to swap it out, this would be the time if there is an issue.
Behr has been bought out by Mahle.
I found this Behr at Advanced Auto parts. Not cheap!
https://shop.advanceautoparts.com/p/beh ... icle=false
- 11 Replies
- 9964 Views
- 5126 Views
- 32 Replies
- 18155 Views
Last post by sleddriver
- 16 Replies
- 1456 Views
- 21 Replies
- 4437 Views
Last post by PeteB
