Parting out cars online etc or just send them to the junkyard?
- Clemens
- Has thanked: 501 times
- Been thanked: 228 times
Most probably Cocaine ... Or snow.
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Clemens
The heated rear seats are rare, I'd buy them right away if you were in Europe. If you have the time, pull at least the wiring harness, switches and possibly the heater mats.
The center console is easy to get out.
If you own one of these, I'd keep body panels, doors, headlights, taillights and alot of the smaller stuff.
Definitely pull the MAF if working, and the ECC (AC control unit)
1996 855 R,
2010 V70 D5,
2010 V70 D5,
- Has thanked: 1613 times
- Been thanked: 4078 times
I can get these from CO to Ny for free. And probably to Austria later this year.Clemens wrote: 10 Dec 2024, 15:15 The heated rear seats are rare, I'd buy them right away if you were in Europe. If you have the time, pull at least the wiring harness, switches and possibly the heater mats.
I think just the seat bottoms are heated? That console will be harder but isn’t it just the rear switch plate you need ?
- foggydogg
- Has thanked: 83 times
- Been thanked: 405 times
I would imagine there is a dedicated harness, and being a Euro model it may be specific to that market. I don't remember seeing a lot of loose unused connectors back there.abscate wrote: 11 Dec 2024, 03:18I can get these from CO to Ny for free. And probably to Austria later this year.Clemens wrote: 10 Dec 2024, 15:15 The heated rear seats are rare, I'd buy them right away if you were in Europe. If you have the time, pull at least the wiring harness, switches and possibly the heater mats.
Harvesting the heater elements would mean skinning the cloth off; not a lot of work, but a bit better than for such rare stuff going to the crusher.
Now if it had the desirable heated third row...
coop
- Year and Model: 1998 s70 t5
- Has thanked: 17 times
- Been thanked: 15 times
It’s a us market car. It was just purchased overseas and spent its first few years in Germany. But it’s got the correct speedometer and other North American specific parts.
coop
I’ve seen the directions for an early s70 with heated rear seats so I’m just assuming the 850 is designed in a similar manner.
I like how Volvos are wired. At least each component usually goes back to the wiring harness/block or whatever so if you follow it you can unplug the whole thing. I noticed they do that with power for the amp etc.
There’s probably a fuse too for these too huh?
https://www.fcpeuro.com/blog/how-to-ins ... vo-s70-v70
coop
This is what I found that should be the parts list for rear heated seats
9128541-Switch
9128542-Switch
9148513-Harness
3523201-Relay
9132197-heater element 2 required
9138876-heater element 2 required
9128541-Switch
9128542-Switch
9148513-Harness
3523201-Relay
- Clemens
Ah, just the seat bottoms are heated. that makes everything easier.
The comment about the Center console was only to point put that the removal of the wiring harness ist not very complex.
Thank you for the offer, Steve. I might grab that chance if @coop is willing to pull the parts
1996 855 R,
2010 V70 D5,
2010 V70 D5,
coop
It looks like it’s going to be nice the next few days so I can pull them. Looks like getting the seat back off is tricky but I did see that the heaters pn where available at a few dealerships state side still and like $26
