Steering Column Switch Housing, Part Number: 31318972, looks like under $300 to replace and has a SW reload (9438286) but I'm skeptical it's really required.
Wonder if maybe the dealer is not fully understanding the issue at hand and is instead pushing you to install a new clockspring (SAS), PN 31313083 which runs around $700 retail. Noted SW reload as well but SAS have been installed successfully without a reload (just need to make sure you have the right part).
Left and right stalk no functions. Replaced stalk nothing. 2006 xc90 V8
aaron1611
- Year and Model: 2006 XC90 V8
- Has thanked: 2 times
- Been thanked: 5 times
Thank you for each of your responses. I'll check to see if any water got into the CEM today. I called my local indie shop and they said they can't install the SWM due to the software upgrade. I'm also getting code CEM_1A5E communication with the SAS control module signal missing. Also, BCMU012587 lost communication with steering angle sensor module.I think I'm going to have to bite the bullet and take it to the dealership as it's just no safe driving without blinkers etc. I'd rather not spend the money but my DIY skills are lacking.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
91 240 Wagon 5 speed 211K daughters daily driver sold
2013 XC90 wife's daily driver 201K
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
Volvo's that were driven and flipped:
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
aaron1611
So, in the end I had to take it to the dealership and had the steering wheel module replaced and that fixed the problem.
2005 Volvo XC90 V8
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
2006 Volvo XC90 V8
06 XC90 175K sold
02 V70 XC 135K sold
05 XC90 251K sold
92 240DL 215K
01 V70 TMU
00 S70 100K
99 V70 189K
94 940 136K
92 240 GL wagon TMU
85 240 DL 196K
90 240 DL 169K
95 850 wagon 250K
99 S70 135K
Vova585
- Has thanked: 228 times
- Been thanked: 238 times
I would start with trying to find correct wiring diagram for SWM. Make sure it gas all power and grounds. Then check if Lin bus wire is continuous to CEM. If all checks out good, remove the SWM and send to xemodex for repair. If can't be fixed, they will sell you used unit and flush your vin into replacement part it will be plug and play.
Sorry. Missed the message that issue was fixed.
- 2521 Views
Last post by chrisb315526
- 553 Views
Last post by volvolugnut
- 1539 Views
Last post by mrbrian200
- 664 Views
- 824 Views
