new battery, dead radio buttons
lovelyleslie1981
- Year and Model:
It's not a POS because it's possessed, it's a POS because it's on it's last limb anyhow. Even the door hinges are broken. No electrical modifications at all.
zenmervolt
- Year and Model:
Door hinges or door stops? Broken hinges would be rare, but broken stops are a common problem.lovelyleslie1981 wrote:It's not a POS because it's possessed, it's a POS because it's on it's last limb anyhow. Even the door hinges are broken. No electrical modifications at all.
I still think you have a dead-short somewhere. Like I said, put in a fresh battery and measure current draw with the car off. It should be very low. If it's low, you may simply have a defective battery.
'98 Volvo S70 T5 SE
'86 Porsche 951
'76 Porsche 914
'86 Porsche 951
'76 Porsche 914
lovelyleslie1981
- Year and Model:
It's the hinge. I can't explain it. It happened with one of the doors on my last 850, too. NO I have not been swinging on the door like a monkey! But for some reason everyone thinks I have. Charged the battery (a brand new one. 20 days old. it was totally dead) put the battery back in today sans the bells and whistles from yesterday and it seems to be working fine. 12volt battery measured over 12 when we put it back in and with the car running the charge was over 13. That means the alternator is working, right? Hell, what do I know about cars. I went to a women's college. I can talk your ear off about anything, though.
lovelyleslie1981
- Year and Model:
Oh I'm insulted. I've had experiences with Texans. You guys are a breed all of your own.srnkanator wrote:Just trying to keep my good Karma on the Vovlo front . . .besides everyone knows the peaches in Georgia may be sweet, but the Texas peaches will always be bigger
zenmervolt
- Year and Model:
A 12-volt battery, fully charged, should read at or above 12.6 volts. By the time it reads only 12.0 volts fully charged, it has only 25% of the rated capacity. At idle the alternator should put out between 13 and 14 volts. 13.5 is typically listed as nominal.
Sounds like it's charged as it should be and that the alternator is working properly too.
Can't understand the door. Very rare for a hinge to break. The little bronze-colored stopper in the middle between the two hinges, sure, that happens all the time and the door will swing free, but the hinges (painted body-color, one at the top and one at the bottom) aren't something I've heard of breaking normally. Hope you have better luck in other areas!
'98 Volvo S70 T5 SE
'86 Porsche 951
'76 Porsche 914
'86 Porsche 951
'76 Porsche 914
lovelyleslie1981
- Year and Model:
Ladies and gentlemen, we have lift off! Unless my boyfriend just lied. Apparently the radio works now. Got the code in and everything.
- 1704 Views
Last post by Swedeneed
- 1006 Views
Last post by BEJinFbk
- 2584 Views
Last post by BorisBadenov
- 4253 Views
Last post by SonicAdventure
- 1409 Views
Last post by nakamichi
