1998 Volvo s70 sudden no crank no start condition
Cees Klumper
- Year and Model: 2002 S80 T6
- Has thanked: 46 times
- Been thanked: 33 times
Check the quality of all main battery connections and cables. They can appear fine from the outside but be corroded inside. I'd actually try running jumper cables alongside the existing cables from battery to starter and ground, see if that fixes your issue. Then if need be try a different known good battery. If this isn't it either I would suspect the starter itself.
