2008 S60 2.5T, Misfires on cylinders 1 and 3
Vova585
- Has thanked: 228 times
- Been thanked: 238 times
Any chance this car was in the hands of "crafty teenager" that was trying to tune it? K&N filters, straight pipes, etc? I am scratching my head what can possibly be wrong.
Another not very expensive option is to buy a harness for ignition coils.
https://ebay.us/m/gg55uO
Vs replacing connectors for 1 and 3 ignition coils. Possibly the cracked insulation is causing short to power or short to ground. If that's not helping- advance level diagnostic with scope is you best bet.
XC70Rider
- Year and Model: 2007 XC70
- Has thanked: 36 times
- Been thanked: 42 times
I replaced the IGN coil harness 3 years ago. The heat under that valve cover caused the pigtail connectors and wire loom to get fragile. I had all the pigtails zip tied to the IGN coils before I replaced the harness. Instead of risk it with a new aftermarket harness I got a used harness from ERIE Volvo. No issues since installing it.
With the coils over 15 years old I threw on 5 new Volvo IGN coils I got at FCPEURO. Also traded in the 5 Volvo lifetime warrantied spark plugs.
I've kept the valve cover off since then so the heat can escape.
Check page 4 of the wiring diagram I attached.
- IGN Harness from ERIE Volvo.jpg (52.02 KiB) Viewed 391 times
- IGN Harness.jpg (138.3 KiB) Viewed 391 times
wiring harness.pdf- (12.09 MiB) Downloaded 59 times
- DavidE7
- Year and Model: 01-07 V70, S60, XC70
- Has thanked: 67 times
- Been thanked: 93 times
If the simple solutions aren't finding the problem there are some more complex things to check.
My S60 had misfire codes for cylinder 1 and 3 after the PCV check valve lost its guts into cylinder 3. See the post below for the diagnostic details. Compression test will provide clues. A bohr scope view inside each cylinder will let you see any mechanical damage from something foreign getting into cylinders 1 and 3 and also allow you to rule out a leaking head gasket with coolant inside the cylinder.
viewtopic.php?t=86687&hilit=Banjo&start=30
Good luck!
Good luck!
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 231,000 miles
2004 Nautic Blue XC70 2.5T 258,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 277,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 203,000 miles
P2 Volvos for every person in my family
professorsunshine
- Year and Model: 1996 850 Turbo
Bad news. I did some more testing today with different tools. I may have gotten my numbers mixed up or something, but cylinder 3 indeed has no compression. 0, zilch. That explains most of the issues I was facing.
So now I'm moving forward with replacing the cylinder head. Can anyone tell me what cylinder heads are compatible with the 2.5T engine with VVT on both cams?
- 384 Views
Last post by coop
- 2811 Views
Last post by mtd240
- 1465 Views
Last post by Masscomguru
- 14 Replies
- 12415 Views
Last post by pgill
- 41 Replies
- 14021 Views
Last post by Sweedy
