Brand new battery indicating to ‘replace’ 2 days, Car goes haywire when trying to crank. 1998 C70.
Has thanked: 2209 times
Been thanked: 1852 times
We always appreciate when members take the time to close out the issue as it is a great help for others trying to diagnose these issues.
Thanks,
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
Note to future people who find this thread: Simple check to voltage at battery while engine running will often indicate if you have a bad charging system. You need to have about 13.5- 14 volts if charging.
Has thanked: 1611 times
Been thanked: 4072 times
Usually this battery drain is caused by diodes in the alternator that have shorted to low ohms, the battery just runs current through them until they are dead. You can diagnose this but playing with unfused , high current stuff isn’t electrical 101 - you can start a fire and/or hurt yourself doing this
You can safely symptom diagnose by removing the hot cable from the alternator amd seeing if that stops the drain.
That means…
Charge battery
Disconnect negative terminal
Disconnect positive at alternator. Cover with heavy rag and tape
Reconnect negative
Leave overnight.
If you are battery drain stops, voila.
Hoser99
Year and Model: 2000 c70
Been thanked: 3 times
Post by Hoser99 »
Touch with your finger - the positive battery post where it connects to the red plastic sheaved cable leading to the starter.
If its hotter than everything else around it the copper wire has gone bad where it joins the positive battery cable. This is causing high resistance and the cable will get hot. - this can also cause some oddball faults too. - when cranking the ( uses lots of power ) voltage drops so low that many of the other sensors are below their reference voltage and they main computer thinks they’ve all gone off-line at the same time. “ car goes haywire while cranking “
you can fix temporarily - remove the cable clamp at bottom of battery to create some slack. Cut a few centimetres off the end of the cable until you see bright copper coloured wire and reattach it to a new aftermarket battery post - like one from PICO.
when working properly the post wont be hot, it will be same temp as things around it after a short drive.
Good luck 🇨🇦
