Driveline vibration 2016 XC90 T6 164k miles
Pretribrapper
Year and Model: 2011 C30 2.0 T5
Has thanked: 59 times
Been thanked: 9 times
Post by Pretribrapper »
Wow. Thanks for this. I put the 3 in front and the 25 in back and no difference whatsoever. Not sure if I just deal with it or swap all 4 tires and hope
Vova585
Year and Model: 01v70xc,2016xc70...
Has thanked: 228 times
Been thanked: 238 times
Post by Vova585 »
You mentioned you have a T8. I am not sure if tires are the same or similar, I would first swap tires from one car to another and see if there would be any difference prior to dropping 1200-1500. If this is not an option, I would buy a proper disk runout measuring tool and see if the problem is with rotors. Alternatively just bring to dealer and see what they can come up with.
Pretribrapper
Thank you again for the advice. I will try these. It is so odd. It really just feels like a fine vibration in steering wheel that is constant between 50 and 70 and seems to come and go a bit at lower speeds. No difference if im pushing on brakes or not but when slowing to a stop from 10 to 0 it comes and goes fairly noticeably. So odd...
