1992 850 GLT crank no start, no spark
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
Another suggestion that may help others see and diagnose your no-spark condition: take and post a photograph of the engine bay and especially the area around the ignition coil.
zero2218
Year and Model: 1992 850
Been thanked: 2 times
Post by zero2218 »
Replaced the ignition coil and camshaft sensor today. Still no start. Cannot replace the distributor rotor due to a damaged bolt head but it is spinning along with the crankshaft.
I have a doubt about my firing order and if it is correct or not. In the specifications document the firing order is 1-2-4-5-3 (clockwise) on the distributor. However guides like this one says it is 1-3-5-4-2 (clockwise) https://www.matthewsvolvosite.com/volvo ... ing-order/
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
If I recall correctly, two adjacent cylinders firing in order only occurs once on these engines.
1-3-5-4-2
1999 V70 GLT
jreed
Post by jreed »
zero2218 wrote: 17 Aug 2026, 07:30 Replaced the ignition coil and camshaft sensor today. Still no start. Cannot replace the distributor rotor due to a damaged bolt head but it is spinning along with the crankshaft.
If your rotor bolt won't come loose, you may be able to get it to come free using locking pliers, as shown below: viewtopic.php?t=93539
zero2218
Post by zero2218 »
Still no luck with the distributor rotor replaced. I will perform some tests tomorrow and seek some advice around my area.
zero2218
Post by zero2218 »
Did some testing today. Spark at the coil but still none at the plugs. Tested several cylinders to be sure. The only ignition part I didn't replace yet is the distributor cap. I wonder how replacing it would fix the issue considering its looking good and clean.
RickHaleParker
Been thanked: 980 times
Post by RickHaleParker »
zero2218 wrote: 26 Aug 2026, 05:33 The only ignition part I didn't replace yet is the distributor cap. I wonder how replacing it would fix the issue considering its looking good and clean.
Look for tiny cracks in the Cap and Rotor. Flip the Rotor over and look at the bottom side.
Still recall being stranded overnight because the Rotor was cracked. All the power was going straight to ground through the shaft.
Active
Past
jreed
Post by jreed »
When you are testing for spark at the coil and at the plugs, are you using the same grounding metal for the test?
Asking because it could be a poor/high resistance ground on the engine block is preventing the spark at the plugs.
zero2218
Post by zero2218 »
No visible cracks in the cap. Looks in good shape. The rotor is replaced now.
I believe a cap replacement would end the doubt about it.
