V70 2004 I just lost drive.
Has thanked: 2196 times
Been thanked: 1850 times
Biggest issue I find is using aftermarket 'C' clips holding the axles in. The profile of the clips are often too rounded and don't hold in the transmission when loaded sideways like when turning.
Has thanked: 1609 times
Been thanked: 4063 times
It also helps to use axle grease to “glue” the circlip in a centered way on the axle so it is getting squeezed equally when pushed in.
I need a pic to describe thst better, methinks
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
It helps to blow compressed air inside the diff satellite to get dirt and rust out. Greased axle goes in much easier then.
jonesg
Year and Model: 2004 V70
Has thanked: 73 times
Been thanked: 532 times
Post by jonesg »
abscate wrote: 16 Aug 2026, 03:52 It also helps to use axle grease to “glue” the circlip in a centered way on the axle so it is getting squeezed equally when pushed in.
I did that, also removed the knuckle so it was easier to get the axle lined up.
it went in a lot easier than it came out.
