2001 S60 2.4L U.S. ~ PCV System
To put it simply jbray, they will remove your intake manifold to access a plastic box with 4 openings, and clean or change it. If this is completely out of budget, you could try the following. Introduce 1 ounce of Seafoam into one of the two hoses going to the canister. Run the car to temperature or 5 minutes. Do this 4 times before changing oil. If fixed by then, use a high miler oil thereafter. PS, have a general mechanic help you.
88 Volvo 760T
90 Volvo 760T
94 Volvo 855T
99 Volvo C70
04 Volvo V70
04 Volvo S60R
90 Volvo 760T
94 Volvo 855T
99 Volvo C70
04 Volvo V70
04 Volvo S60R
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
The repair looks like this. A PITA, but doable by most home mechanics: http://lakesidedp.com/uploadpics/pcv/jbray.cfm wrote:summerpryncs:
I'm have the same problem that encountered... Can you please elaborate on your repair? My Volvo dealer would say a whole heck of a lot, however, he wanted me to dish out $880 to make the repair... Do you have any part numbers of what was replaced? Any help would be appreciated.
-JBray
- Has thanked: 17 times
- Been thanked: 35 times
Since he's asking about an S60, it will be a little different (less hoses) but generally the procedure is the same.
I went even further with my imaginary repair. Into the upper PCV hose use a syringe to inject the ounce of Seafoam. Just leave the needle during each step of the above treatment. Because of the sound the car makes when blocked, it will also tell you when it's unblocked.
88 Volvo 760T
90 Volvo 760T
94 Volvo 855T
99 Volvo C70
04 Volvo V70
04 Volvo S60R
90 Volvo 760T
94 Volvo 855T
99 Volvo C70
04 Volvo V70
04 Volvo S60R
I sure appreciate all of the input and information that each of you has taken the time to provide. I have a baby girl due any day now, so I can't dig into the car just yet, however, once she get here I believe that I will tackle this.
Do you believe that this is causing any harm to my car, or just my pride?
Thanks again.
Jbray
Thanks again.
Jbray
Sony2000: I believe this is what you are talking about... http://www.seafoamsales.com/motorTuneUpTechGas.htm
I will give it a try as you mentioned.
Thanks again
Thanks again
Yes, that's it...all auto parts stores (that I know of) carry it.
- 2520 Views
Last post by mickjenkins
- 1272 Views
- 15 Replies
- 3804 Views
- 130 Views
Last post by Antoine240bk
- 476 Views
Last post by JRL
