Well, it looks like I will have to replace the tensioner as it is acting up again. I will hopefully find a used one locally. Thanks to all for the above advice. It will probably be closer to the first of the year before I can replace it. I will post about the experience.
_________________________________________________
1996 Volvo 850T Platinum Edition 170,000 miles
2000 Volvo S80 2.9 80,000 miles
Seat Belt Tensioner
Re: Seat Belt Tensioner
2004 Volvo XC90 AWD - 170,000 miles
2010 Volvo XC60 AWD - 145,000 miles
1996 Volvo 850 Platinum - 201,500 miles - KILLED BY UNINSURED DEER _
dcarlson12
- Year and Model: 1997 850 T5
- Been thanked: 2 times
You might want to try some silicon lubricant rather than WD40. WD40 is more of a solvent than a lubricant and from my experience it seems to evaporate quite quickly. Whereas silicone spray is actually a lubricant and will 'hang around' for a quite awhile.
Keep us informed as to how you make out....
Ok, so it has started acting up again. You have to yank on the belt to get it to advance the belt to the point that you can buckle it. I am going to put one of those baby seat tensioner things on it to hold it out so it doesn't take as long to get buckled up. Then I am going to start looking for a used drivers side tensioner.
Does anyone know if the tensioners are the same in the 2000 model S80, S60, V70, etc? Or is the same tensioner used across a few years?
__________________________________________________
1996 Volvo 850 Platinum Edition - 170,000
2000 Volvo S80 2.9 - 88,000
chattiniii
- Year and Model: 1995 850 120000
After reading this and having the same problem, I sprayed my reel lock mechanism with break cleaner. It is now like new! Thanks! Chatty
- 194 Views
Last post by RedBrickCollector
- 2142 Views
