I do not now the torque specs for the t-starter cover bolts or what NE1 is. Do you?
Also, I do not know what the torques spec tool looks like. Plus, I have not been able to find backup bolts in the event I strip or break one. Do you know a sourse that sells all of the parts.
I tried these parts places, but either on has all that I need, so I would have to go to two different places. Either one had the bolts or replied to an email.
http://www.eeuroparts.com/Main/Home.aspx
http://www.fcpgroton.com/
P0128 Engine Coolant Temperture Sensor location? 2001 S60
- Has thanked: 17 times
- Been thanked: 35 times
Call either place and explain what you need- I am confident that they can get the parts or it's on their websites- you're just not finding them. If you need a part number for the replacement screw it is 969156 (btw, the screws on top are the same as the screws that mount the housing to the block- 2 on top and 3 on the side if you're replacing the entire housing).
The torque specs for the thermostat housing bolts is 17Nm which is 12 1/2 ft. lbs. You'll need a T45 (I believe) torx socket.
- 825 Views
Last post by Duncx
- 1635 Views
Last post by neworleans
- 7907 Views
Last post by beaters4ever
- 2305 Views
Last post by Scottywell
- 3600 Views
Last post by Ben1968
