Install Keyless Entry
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Schematically it used ground as the common:
http://pliki.mojevolvo.pl/volvotechinfo ... n_3_39.pdf
The server is in Poland and it is slow. Be patient for it to launch.
tjts1
Year and Model: 96 855 NA 5 speed
Been thanked: 4 times
Post by tjts1 »
I'm not sure. I'm only really familiar with the kit I used which seemed really straight forward. Whats the model name of the kit you're using?
Ambitious but rubbish
kaddo
Post by kaddo »
tjts1 wrote:I'm not sure. I'm only really familiar with the kit I used which seemed really straight forward. Whats the model name of the kit you're using?
It's Auto Star AS-830 (manufactured in Taiwan by Astargek)
I'm trying, but not much info that I could find on the Web.
850 GLE '96 Wagon, 5-spd.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
The button should just pop out. On the back are the lock and unlock leads
along with the ground that they each need and a dash light lead.
Sounds like you've got a good handle on this bit of fun.
All you need is a ground for lock or unlock.
These PDF's may help.
96 850 wagon lock comp diagram.pdf
(150.04 KiB) Downloaded 625 times
96 850 wagon lock comp location A.pdf
(231.69 KiB) Downloaded 426 times
96 850 wagon lock comp location B.pdf
(244.55 KiB) Downloaded 437 times
kaddo
Post by kaddo »
BEJinFbk wrote:The button should just pop out. On the back are the lock and unlock leads
Many thanks for the valuable info and much needed encouragement, BEJinFbk!
BEJinFbk
Post by BEJinFbk »
No Problem. That's why we're all here, eh? :wink:
The best part is, It'll seem a lot easier once your done!
:mrgreen: Enjoy having a remote!
kaddo
Post by kaddo »
BEJinFbk wrote:No Problem. That's why we're all here, eh? :wink:
If thinking you weren't abused so far, I will try harder now. ;)
I have a question about A/C on these cars, could you help?
Post by Ozark Lee »
Start a new topic with your questions.
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
I ordered one of these (omega REC-43T) and installed it today.
Super easy. You get your power and ground from the wires going to the headlight switch, then tap the other harness into the two lock/unlock wires going into the lock switch. I did it in about 30 minutes, and I soldered all my connections. Just mount the unit down where your wiring harnesses and relays are with some heavy zip ties, and tuck the antenna wire above the plastic trim that covers the knee bolster. Set your jumpers on the unit to "on demand", then program the remotes.
I'm getting about 25ft. of range with it. Not bad for $25.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
kaddo
Post by kaddo »
fattymatty wrote:I ordered one of these (omega REC-43T) and installed it today.
I don't suppose range is an issue with these gadgets, you did well on price, too!
