S40 Temp Dial Question/Problem
gherman
Year and Model: S40 2000
Post by gherman »
I'm about to embark upon replacing the actuator motor on my 2000 S40. Did you have any luck calibrating it yourself?
drvolvo
Year and Model: S40
Been thanked: 3 times
Post by drvolvo »
Yes, if you follow the PDF directions above the damper motor should calibrate correctly when you turn the key to the correct position. I also describe the procedure here https://www.matthewsvolvosite.com/forums ... =8&t=34858
Good Luck
gherman
Post by gherman »
Thanks for your help, Doc. Got a used motor at a junker and it wors fine...today!
Now if I could only get rid of the buzzing I hear on acceleration...
