Any Year, Any Car -- Dial Indicator Mounting
MrAl
Year and Model: v70, 1998
Has thanked: 83 times
Been thanked: 73 times
Post by MrAl »
Hello there,
I have a dial indicator with no arm but will get a mounting arm for it soon so i can check the brake rotor run out.
Question is, what is the best way to mount the dial indicator for making this measurement?
Also, is there any recommended 'arm' + 'base' for a dial indicator for making this measurement?
Thanks much :-)
Acknar
Year and Model: 940, 1993
Post by Acknar »
This is the one I have and use when I measure runout just find a chunky piece of metal typically the caliper bracket and adjust the goose neck, https://www.amazon.com/Fowler-72-641-300 ... cator+base , Make sure you have the centering bolt or the lug bolts holding the rotor tightly before you measure them.
MrAl
Post by MrAl »
Hi,
Yeah i was wondering about that, because if the wheel is off then the rotor may be loose. I have a feeling the old one will be tight anyway, but the new one once put on will not be tight yet.
