XC90 t6 2004 - Bulb Failure Low Beam Topic is solved
I'm having the same issue. A couple nights ago i switched from high beams then back to low and got a warning, "low beam failure". Both front low beams out, I still have fog lights and high-beams. Finding lots of similar problems online. Looking for solution before I buy new headlights. Mine are non-xenon.
- FLXC90
- Year and Model: 98 V70 T5
- Has thanked: 16 times
- Been thanked: 45 times
Try changing the bulbs. especially if you have normal halogen lights, then you can just change low beams. Or try re-seating the connectors. I have Bi-Xenons, and the surge when one popped took out the other. Replaced both bulbs, been good for a year now. KISS works
Of course if you have Bi-Xenons, and the bulbs check out, cry...a lot
Current Volvos:
shellshockgw
- Year and Model: Too many to list
- Been thanked: 2 times
Sorry for the holy massive threadbump but I just solved this exact problem on a customers 04 XC90. I figured I'd share it for anyone else in the future searching the net for a solution.
Check fuse 38 INSIDE the car on the drivers fuse panel. Mine was blown. Lights are working again!
- Has thanked: 987 times
- Been thanked: 1075 times
Early P2s (and later?) may have a problem with failing headlight wires. Heat appears to degrade the insulation.
- 4859 Views
Last post by adrian22
- 3397 Views
Last post by THAI UNG
- 28394 Views
Last post by karisa60
- 19 Replies
- 7696 Views
Last post by cn90
- 8879 Views
Last post by mrbrian200
