Drain on Battery 1997 850 GLT
This topic is in the MVS Volvo Repair Database » Drain on Battery 1997 850 GLT
w5bvb
Year and Model: s60 2006
Post by w5bvb »
Sorry, but your analysis is wrong. Any current flowing through
the battery has to flow through both the positive and negative
terminals. So it does not make any difference whether the test
device goes in the + or the - path. The only case where the + lead requirement makes sense is if there is acid/corrosion/crud
whatever making a leakage path to ground from the negative terminal. Good luck with the hunt for the problem as I have had
the same thing on my 95 850 turbo and the problem seems to
have gone away without my finding a definite cause though I did
disable the glove compartment light. Frankly, I suspect a relay
was sticking somewhere. Thanks, Phil
graydawn
Year and Model: 1997 850 glt wagon
Post by graydawn »
Check Battery first ...it was fine. Used test light, went on for a second or two, when first connected, but then went out. Strange! Still draining battery, Seems to be faster now. Going to give a couple of things a try. Think it might be ABS problem.
thanks for all the posts. Any more suggestion appricated
hutch
graydawn
Post by graydawn »
I have check the Battery. Good!.... I pulled each fuse twice ...plus the back outlet one. Test light still on! Pulled all the fuse out at once. Test light still on!
Any one have Any other suggestions! Really stumped on this!!
Thanks Hutch
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
It could be a problem with the alternator. Disconnect it there (with the battery cable removed while you are disconnecting it) and see what happens.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 94 times
Been thanked: 146 times
Post by BEJinFbk »
w5bvb wrote:Sorry, but your analysis is wrong. Any current flowing through
+1 on both terminals being part of the current flow loop.
Bad grounds will still be part of the equation for either battery terminal.
+ or - , the draw will be the same on either.
As for "Ya gotta use a test light", I disagree. Sure, it works...Kinda.
It's just a much cheaper "analog" ammeter for very rough "readings"
A good ammeter is MUCH more accurate doing exactly the same thing.
If you're already using the right tool for the right job, why backpedal?
But that's just me. You may think I'm wrong! :mrgreen:
goober4321
Post by goober4321 »
Now try pulling the relays one by one in the same manner of the fuses with the test light
Volgrrr
Year and Model: '95 T5 wagon
Post by Volgrrr »
I'm sorry if I appear a little bit pedantic, but take the time to go back, read and digest my post correctly because, what you state here is, in essence, no different to what I said in my original post.
There are only two types of car owners - those who own Volvos and those who wish they did.
mcp
Post by mcp »
Going back to basics. The question was asked, but never answered, "How old is the battery?". Twice I read "battery checked - good", but my personal experience is a battery that has reached its limit, may "test good", but be "bad".
This summer, the Interstate battery in my wife's 1998 S70 exhibited exactly what you are describing. It would go dead overnight, even though I took it to my local Autozone to have them test and charge it. It tested "good", took a charge and then went dead overnight. It was a 60 month battery that had gone several months past 60. A new battery was the solution.
So, how old is the battery?
1998 S70, 5 speed manual, 146k, wife's car
1997 850 Wagon, 5 speed manual, 185k, son's car
1996 850 5 speed manual, 220k
1985 MB 300D 268k, running on B20 biodiesel
1983 MB 300D 240k , converted to vegetable oil
1981 VW Vanagon 184k
graydawn
Post by graydawn »
Found Problem Was the Air pump intake relay.
Pauloil
Post by Pauloil »
I used the info here and used neg cable to get 0.14 amp drain until pulling fuse to glovebox light, then 0.04 amp. So my glovebox light was keeping my battery around 12.2V or less. Now 12.37V after long drive today. The pad to shut off the light had hole in center! I used a small square of furniture glide( the glides you put under furniture on nice wood floors) and will super-glue it in place soon to keep the light off. I hope anyone reading this will go out and look at the pad that turns off the light in the glovebox if you have an 850.
99 V70XC 158K
95 850glt 188K
