Brake Pads that don't squeal
tom39
Year and Model: 2011 S80
Re: Brake Pads that don't squeel
Post by tom39 »
Guess what? :twisted: They %&^*&#@ SQUEEL. Back on the lift it goes. I hate this crap. :evil:
11 - S80 Silver 132k/mi
tom39
Post by tom39 »
FIXED IT!!!!!!!!! :lol: 8) :D
After my last post I visited the local NAPA. I picked up some Ceramic Extreme Brake Parts Lubricant. I coated any and all contact surfaces and pins with this stuff and you guess it. IT WORKED!! 8) :D
It has been 9 days and not a peep. If the squeel comes back I will let you know, but I am keeping my fingers crossed.
Thank You everyone for you help and suggestions.
tom39
Post by tom39 »
Well guess what? My right rear brake squeel is back. Not only that but it has a vibration too.
While trying to find another fix, I did some research and I seem to have found a fix for the vibration, its a shim service kit that looks as if it is a 1/2 of a shim that would cause the pad to tilt some and hopefully sit flat on the rotor. It is an OEM part and was bought at the dealer.
Has anyone utilized these shims and if so did it work, or am I on a wild goose chase? Am I on the right track and could this also be the issue I am having with the squeel all along?
Any suggestions would be welcomed.
9394volvo850s
Year and Model: 93 850 5spd 94 850T5
Post by 9394volvo850s »
man im dreading the fast approaching day that i have to change my rear pads in my 93. neither of my 850 have any sort of squeel. i have auto zone carbon metalic on the front of the 93. dont kmow thats on the 94 turbo.
93 850 5spd 320k (the daily)
94 850 T5 190K (race car)
95 T-5R wagon yellow (summer wag)
90 745 5spd 295k (winter wag)
67 122 2 door 4spd 69k :))
V70Johnson
Post by V70Johnson »
About a year ago, I changed out front rotors & pads. Went with OEM, purchased directly from local dealer (crazy or what?) While they ARE quite dirty, I haven't heard the slightest noise from them...under all driving conditions.
My two cents.
BlackThunder
Year and Model: 1997 850
Has thanked: 6 times
Been thanked: 3 times
Post by BlackThunder »
I'm ordering those OEM pads from FCP Groton today. This is my first time installing rotors and pads. I'm looking forward to it and to getting rid of the "warped" rear rotors.
Dustin
Dustin
2013 Volvo C30 T5
1997 Volvo 850 NA Sold to a New Volvo Enthusiast
tom39
Post by tom39 »
Well I installed the shim kit soon after my last post and it appears to be the solution. The shim kit contains what looks like 4 shims but with half missing (see link) http://www.fcpgroton.com/images/product ... 272272.jpg
I installed the shim to the back of the pad that had irregular wear caused by uneven applied pressure due to not seating flat. It took about 25 miles of driving but the pad soon thereafter settled down and the squeel and vibration went away. I tested it in DC rush hour traffic about a week ago and I am golden.
I hope that any of this helps and a thanks to all for your help and suggestions.
TOM
BlackThunder
Yeah, those shims (with the arrows up) work well. I've been very satisfied with them. Good work!
Dustin
Dustin
2013 Volvo C30 T5
RSM-GA
Year and Model: C70 T5 Coupe 2002
Post by RSM-GA »
I have a set of these half shims I am going to install. Which direction does the arrow face on installation right or left?
thanks
Rob
[img]C:\Users\sony\Pictures\2010-01-17[/img]
My garage:
2002 Volvo C70 T5 Coupe
1998 Volvo S70 T5 91k sold
1999 Volvo S70 190k scraped
1999 Mercedes Benz E320 199k sold
2000 Volvo V70 SE sold
1999 Taurus SHO V8 sold
Timberwolf530
Year and Model: 1994 850
Post by Timberwolf530 »
tom39 wrote:Well guess what? My right rear brake squeel is back. Not only that but it has a vibration too.
I have been using the Disc Brake Quiet (the red spray) for years with great results. I've found it is common for disk brakes to squeal a little when new until they settle in. I did mine on my 94 850 about 6 mos ago. I used Duralast semi-metalic with the spray. They squealed for about a week, and have been quiet ever since.
1994 850 Wagon - My car is on it's 3rd generation in my family. "I don't look at it as doing repairs, I see it as doing a complete restoration one part at at time."
