Emissions test... P0442 p0445
ThommyKent
- Year and Model: 91 245 97 850 T5
- Been thanked: 5 times
On a S80 anyway
Auburn T5
- Year and Model: 1999 S70 T5
- Been thanked: 2 times
Back the car up onto rampsThommyKent wrote:I just repaired this hose as it had a very small crack at the hooked end. It fixed the p0455 code that kept returning. Maybe on a lift it`s not to bad a job, but`s not a lot of fun on the floor.mdvolvo wrote:I worked on volvo for over 25 years but now do it as a hobby.
Here is the fix.
There is a hose that is attached to the evap canister and valve that is cracked. They all do. It is about 9 inches long with a hooked end.
The canister is located above the rear sub frame of the car directly in the middle.
Remove the right rear wheel and look straight through the gap and the one end of the hose can be seen attached to the canister.
Replace the hose and that will solve that evap leak problem
Not too much of a difficult job
2020 - Tesla Model 3 Performance
2020 - XC60 T5
1999 S70 T5 - Bilstein touring shocks/struts, B&G S2 springs, OBX full exhaust, other misc. stuff
2020 - XC60 T5
ThommyKent
You're still on the floor with ramps
- 1255 Views
Last post by t1adler
- 2604 Views
- 1523 Views
Last post by Lasershark
- 33 Replies
- 3000 Views
- 11 Replies
- 1993 Views
Last post by Eddystone
