850 automatic transmission
This topic is in the MVS Volvo Repair Database » Classic PNP Switch Shifting Fix
yellowpuulwater
Post by yellowpuulwater »
OK, my 95 850 turbo (auto) started leaking transmission fluid, quite badly at some times, and last night, i was out having some fun, and i noticed the clutch slipped 3 times in three separate occasions last night. Anyway, i passed it by as nothing, and kept goin (100+mph). This morning, i get in, and when i go to leave, RPMs go to 4000, and i wasnt moving, and around 5000 i started to move, and then quickly moved down to 2400, and finally caught, and all was good. Got to a stop sign, and it happened all over again. I took it to a tranny garage, and he said it was done!! Did this happen to u guys, and what did you do? (my orange arrow light started blinking, and my check engine light came on) Recently added sport exhaust, and cold air intake system, but, they have nothing to do with the tranny !!! please help me !!
~pts.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
Have you changed the fluid lately?
Checked the level of fluid?
The smell?
The color?
These things are important, but to me -- accross the internet -- it sounds like your trans is going. Mine in my 850 is still good, but I had a Chevy long ago, and the symptoms were the same as yours. Also, all that extra power certainly wears the transmission out sooner.
Also -> Amazon link
tobin
Post by tobin »
Well I replaced the pnp and this fixed all the problems I had previously. Car shifts fine even when cold and 313 and lock up slips codes gone. However, now my tranny shifts irregularly, especially when accelerating quickly like it can't decide which gear it should be in. Is this an ECU relearning that will improve shifting or anyone else have suggestions? -Fluid has been changed twice recently. FYI, switching to synthetic on an older volvo is a BAD idea. I tried it on 2 and had to flush an remove it completely due to horrible shifting afterwards.
Guest
Post by Guest »
1994 850. 230K
850Gas
Post by 850Gas »
What is bay13? I am going to replace my PNP switch! My car is doing all of this type of stuff!
pfeener
Been thanked: 2 times
Post by pfeener »
Bay13 is the name of the maintance section on the volvospeed.com site.
jabber
Post by jabber »
Hey all. So could the PNP switch be the cause of crappy shifting predominantly from second to first. I am getting a clunk most of the time but not always. Upshifts are less smooth than they used to be as well. The car is a 1999 S70 non-turbo. I am taking it into the dealer for a tranny flash tomorrow to see if that will correct the problem. No codes from OBDII. No up arrow. Very weird...
Jordan.
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
850Gas wrote:What is bay13? I am going to replace my PNP switch! My car is doing all of this type of stuff!
It is the maitenance section of this site (look to the left column) www.volvospeed.com
Good luck!
h2oiamwater
Post by h2oiamwater »
i cleaned out the whole switch and took me 2 days....but took less than 4 hours...i cleaned all the contact points and springs but light still flashes...how to get rid of the light...any ideas.... anything else to clean.
beating a honda is like doin your mom, anyone can do it...but who wants to brag
95 850 turbo
ShahinS
Year and Model: 850 GLT Wagon 1996
Post by ShahinS »
Guest,
Please explain how you replaced the switch without the alignment tool. Much appreciated.
Cheers,
Shahins
96 850 GLT Wagon
