Good, bad or ugly? Bosch Spark plugs re: 1994 850 B5254F
Year and Model: 2004 V70 2.5T
Been thanked: 504 times
Post by cn90 »
Just replaced my Bosch spark plugs.
4y/25K ago: I used Bosch 7555 (FR7DC), made in Brasil, after 25K miles, the gap went from 0.028" ---> 0.032", which is normal wear/tear.
This time, I use Bosch 79555 (FR7DC+), made in Germany, $1.99/each at Autozone.
I followed Ozark Lee's advice and set the gap to 0.028".
For N/A (non-turbo) engines, I guess you can use either Bosch 7555 or 7955.
See the picture.
MilehighV70XC
Year and Model: '99 V70XC, 143,000mi
Post by MilehighV70XC »
Is the threaded section on the 7955 plugs longer then the 7555? Maybe it is just the angle of the picture, but the 7555 looks to be shorter.
SpeedyPete
Year and Model: S70-T5, 1998
Post by SpeedyPete »
Hi Guys: I have been running the Bosch 7955 supper plus in my T5 for years with great success, never a problem. However, I also change them out at 15,000 mile intervals. At $10.00 a set, just part of the routine at 15,000 mile service I do. Best Regards, SpeedyPete
Post by cn90 »
MilehighV70XC wrote:Is the threaded section on the 7955 plugs longer then the 7555? Maybe it is just the angle of the picture, but the 7555 looks to be shorter.
The old plug had some antiseize on it, but if you look carefully, both 7555 and 7955 hae the same number of threads (about 12).
tjts1
Year and Model: 96 855 NA 5 speed
Been thanked: 4 times
Post by tjts1 »
I've had Bosch 7401 in the 850 since april 2011 and may 2011 in the 960 without any problems. Its a 4 electrode copper core plug (not to be confused with the platinum garbage). This is the first time I've been happy with Bosch plugs in years. Normally I stick with Denso. A friend in the UK turned me on to these and I jumped on them when Amazon had then on sale $1 each.
Ambitious but rubbish
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 20 times
Post by jblackburn »
tjts1 wrote:I've had Bosch 7401 in the 850 since april 2011 and may 2011 in the 960 without any problems. Its a 4 electrode copper core plug (not to be confused with the platinum garbage). This is the first time I've been happy with Bosch plugs in years. Normally I stick with Denso. A friend in the UK turned me on to these and I jumped on them when Amazon had then on sale $1 each.
I didn't even know they made such a thing! Any gains that you can tell vs a standard one prong copper plug?
'98 S70 T5
2016 Chevy Cruze Premier
tjts1
Post by tjts1 »
If there are I couldn't tell the difference from the old copper Denso plugs. At least theres no down side thus far. I'm assuming the multiple ground electrodes will last longer than a single electrode plug.
waynej
Year and Model: 1999 S70
Post by waynej »
I am using the genuine Volvo plugs with the 4 ground electrodes.
On the older engines, when we only had 1 electrode we would index the plugs for maximum performance. Champion sold indexing washers of different thicknesses so we could have the gap facing into the direction of airflow in the cylinder.
I am guessing the reason they now have multiple gaps is because in modern engines the airflow changes direction with RPM, especially with VVIS.
The OEM's are expensive. Has anyone compared the performance or mileage between the single and quad gap plugs?
waynej
99 S70
96 854
87 245 wife's car
94 850 sons car
94 850 2nd sons car
Previous Volvos
93 850
87 744
85 244
82 244
80 244
78 244
78 245
76 265
71 P1800
71 142
Post by cn90 »
According to the BM E39 forum, similar discussion happens many times and the consensus is:
- Single-prong is better than Quad.
- Indexing spark plug is a myth.
tjts1
Post by tjts1 »
cn90 wrote:According to the BM E39 forum, similar discussion happens many times and the consensus is:
Well thank goodness we don't drive E39s :D
