[From experience]
First, if you have to drill, use a center punch first to make sure you center the drill spot. (Make sure and cover any openings where chips could cause damage)
Second, if you can get one, use a left hand drill bit as often times it will end up unthreading the broken bolt out without having to drill large enough to damage threads. (Use drill in reverse with this bit)
And lastly, if you use an "ez-out" I strongly recommend the new style that Sears sells. These things are awsome and have never failed me.
Ok another problem...big one this time...and stupid
VolvoS70Driver
Doug
1998 S70 GLT Blk/Blk
I found some extractor products identical with EZ out but unfortunately i forgot to bring the piece with me so I couldn't decide which size do I need. I will come back tomorrow.
Things are looking bright at least theres a good chance this problem will be fixed tomorrow.
Thanks for all of you who contributed to help. Really glad to have found this website.
06 V70
95 850 se
95 850 se
- 34 Replies
- 4201 Views
- 758 Views
Last post by Sufbug
- 15 Replies
- 2785 Views
Last post by SonicAdventure
- 4275 Views
Last post by Legofan
- 1498 Views
Last post by rguzz
