I was able to use a torque wrench on everything except the tensioner roller mount. I just did it the German method - Gutandtight.
I like to use a torque wrench to get everything back to factory specifications but there are many times that you just can't do it due to space limitations. You must always keep in mind that the block is aluminum so I would recommend erring on the low side, you can always tighten it up later if it leaks or gets loose. With the limited space on many areas even re-tapping and installing a heli-coil is a major PITA if you strip it out into the block.
TIming Belt change Q's for first timer.
- Year and Model: Many Volvos
- Been thanked: 76 times
- tom39
- Year and Model: 2011 S80
I did it without the cam locking tool also. I did however do the same as phils94850 and marked the teeth in relation to a point to the head. The tool would have been nice and removed the worry. But hey I like living on the edge anyway.
One tip I did get from the local Volvo dealer mechanic was to cut the old belt and not try and get it out whole. It saved a lot of time. Your not going to reuse it anyway so why not.
Hope it helped
May the force be with you
TOM G.
Hope it helped
TOM G.
11 - S80 Silver 132k/mi
- phils94850
- Year and Model: 2009 s60 turbo
oh... as lee said its called a "torque wrench " its a pretty tight spot in there putting on a timing belt. Ive done a few of em and never used a torque wrench and never had a problem. Just dont over do it.
1996 Platinum Edition
- misha
- Has thanked: 155 times
- Been thanked: 432 times
Thanks!
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
- 916 Views
Last post by jreed
- 5321 Views
Last post by jimmy57
- 23 Replies
- 17310 Views
Last post by jonesg
- 20 Replies
- 17518 Views
Last post by Hurtfeelings
- 824 Views
Last post by drucken68
