Transmission Flush...
boynamedsue
- Year and Model: 1998 S70 320,000 mi
sorry for my ignorance, but can you explain the difference between a fluid change and a flush?
tblo760
- Year and Model: 760 GLE 1987
Because the torque convertor holds about half the fluid,you are not changing the whole ammount when you drain the sump and re-fill,the best way to achieve a complette change is by flushing with new fluid.This is the best way to do it:-1st,drain the sump,replace sump plug and put back the exact amount of new fluid.Disconnect the return pipe from the cooler and connect a flexible pipe to the cooler out put,and a suitable container,if you're not sure which is the return,you should be able to blow through the pipe that you have disconected,this will blow any fluid back in the box.Now run the engine in park,you will see fluid discharging into the container,you should be able to get about 2 ltrs.,out before it stops,switch off and put back the same ammount of clean fluid.Repeat this untill you get new fluid out of the the flexi,you have now changed all the fluid & flushed the cooler as well.ALLWAYS remember to replace what you take out.boynamedsue wrote:sorry for my ignorance, but can you explain the difference between a fluid change and a flush?
The way of the wicked is as darkness,they know not at what they stumble,(That's why I'm here to help)
polskamafia mjl
- Has thanked: 19 times
- Been thanked: 21 times
A drain and fill involves removing the trans drain plug, draing the ATF out, refilling it, driving, and repeating the process until you get pink ATF on your dip stick or until you feel you have removed almost all of the old ATF. A flush involves hooking up the trans to a machine that forces ATF through the transmission and then back out. There are quite a few threads on this forum discussing flushing vs drain & fill. Here's the link for the drain and fill: https://www.matthewsvolvosite.com/forums ... f=1&t=8767
boynamedsue
I understand now! Thanks guys
Toplights
- Year and Model: 1998 V70 20v Auto Cl
polskamaffia mjl Great Link,exactly the right way to do it imho.Its more expensive than just a drain,but a job worth doing,but only if the TMF is burnt or browny black.polskamafia mjl wrote:A drain and fill involves removing the trans drain plug, draing the ATF out, refilling it, driving, and repeating the process until you get pink ATF on your dip stick or until you feel you have removed almost all of the old ATF. A flush involves hooking up the trans to a machine that forces ATF through the transmission and then back out. There are quite a few threads on this forum discussing flushing vs drain & fill. Here's the link for the drain and fill: https://www.matthewsvolvosite.com/forums ... f=1&t=8767
1998 V70 2.5 Auto Classic.
1996 960 3.0 Auto "Hector"
polskamafia mjl
Thank.
- 1670 Views
Last post by MoVolvos
- 2236 Views
- 21 Replies
- 33420 Views
- 5673 Views
Last post by skippyxc90
- 15 Replies
- 2672 Views
Last post by dux02v70
