buying 240
Thanks for the input. I replaced the fuel relay today and it was cooler, but the engine didn't run any better. I took the in tank pump out and needless to say I think my problems are about to be solved. The + wire waas broken off the pump , the float was not attached to the pump ( it was floating around inside the tank), the hose from the pump to the outside pump was not connected and the ground wire was broken. I am in the process off rebuiding it now, I'll keep you posted. Again thanks
- 1225 Views
- 575 Views
Last post by volvolugnut
- 952 Views
Last post by maverill
- 1293 Views
Last post by ducttapeandzipties
- 1065 Views
Last post by 93Regina
