Service light reset for Volvo V40 and S40 Topic is solved
ptootill
Post by ptootill »
DD wrote:Help! I have a 98 V40 T4 and tried all the usual procedures but all failed.
Mine's a 99 2.0T and I'm pretty sure that I have to turn on the ignition and then hold down the odometer button until light flashes and then release it.
There are IIRC subtle differences from year to year
Rgrds
Peter
guest
Post by guest »
1, Hold down the odometer button
2, Turn the ignition so all the lights come on
3, Keep holding the odometer down for 30 secs or until the service light starts flashing
4, Release the odometer button while service light flashing
5, Turn off and on again to check
Just did that with my 2003 s40
by the way.....why Volvo can't change the programming for service light to go on 7000 miles from last service and not factory set mieage....
sm7tog
Post by sm7tog »
LaoFuZhi wrote:If anyone knows the procedure for a '97 Diesel I'd be obliged....
I have an old -97 V40 Td with the Renault F8Q engine. I have never seen the service lamp in this car while 100 000 km... Does it have one?
Jon
gpt
Post by gpt »
None of the above worked for my S 40 T4 including the diagnostic computer at my garage. Solved the problem by removing the bulb. The unit comes loose easily and bulb can be removed without taking off the steering wheel.
madpup
Post by madpup »
harvey7 wrote: I dont know if anybody knows but there are people trying to sell this information on ebay.co.uk.
Thanks again..........
[/quote]
not any more :lol: :lol:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... 8000953653
CliveBuckley
Post by CliveBuckley »
Tried the above... doesn't work... I'm assuming this is only for 1999 models onwards?
Does anyone know the procedure for resseting the 1998 model...
Also, the Diagnostics computer wouldn't work... kept saying there was an error in the connection to the Control Unit... The Workshop insisted it was a problem with the cars CU, that this is a common fault in Volvo's (altho the car has now done 213 000 KM's and not had this problem before) and not there machine... is this the case?
phaseone
Post by phaseone »
CliveBuckley wrote:Tried the above... doesn't work... I'm assuming this is only for 1999 models onwards?
Does anyone know the procedure for resseting the 1998 model...etc etc
Hi.
I followed the flwg instructions and was working quote
ignition key to position I. push in and hold the odometer rest button (use your left hand). move the ignition key to position II. wait until you see the service light blinking. then release the odometer rest button unquote
if this does not work take the bulb out, so I ll never see it again. :lol:
personally I do not need a light to remember me a service on my car regards
S40 2.0T MY2000 autom
Guest
Post by Guest »
I have a 1998 V40. Two years ago I took it to my local garage for service and they were unable to reset the service light. They said they had all the latest Crypton gear, and that the Crypton man had told them there would be no problem. There was. Days later they came back to me and said they'd heard of a way to do it - the odometer reset way. It didn't work, not did any possible combination of switching and pressing over a one-hour period.
My research on the internet at the time revealed that in the late '90s, car manufacturers in Europe were taken to task about unfair competition, having service lights that could only be reset by franchised Volvo dealers. Crypton brought out software to reset the light at about the same time as Volvo who, anticipating the change in the law, derived the odometer button pressing system. My car seems to have fallen between two reset systems.
Does anyone REALLY know how to rest a 1998 40-series light? I found a way - when my next service was due I took it to be serviced at a Volvo dealer. So much for fair competition! Now the car is due for service again and I don't know whether to use my local man again (and risk having to stare at the service light for another year), or go to Volvo and pay double for havingf the car serviced.
I've had the car since new and thgis is my only real gripe about it. Someone out there (other than Volvo) must know how it's done!
maverick
Post by maverick »
hi could anyone tell me if the procedure for resetting the service light on a 1999 s40 is the same for a 1997 s40 2.0i auto.thanx
mjl99
Post by mjl99 »
I have a 2004 V40 and the way to do it is hold the od reset in turn key to position II, wait till the service light starts to flash then start the car.
I think it should work for you. :wink:
