Nice write-up. I would love to do this to my Volvo but I can't find the vacuum tree. 1995 940 wagon.
[Here is the answer -- Matt]
How to use Seafoam Topic is solved
How to Use Seafoam
researching seafoam for application on my 1997 850, I came across your post: What size rubber tubing did you use to fit one of the capped vacuum port on the vacuum tree. Where did you get or bought it?
I appreciate a quick response…Thank you.
davidprtchrd
- Year and Model: 2004 xc90
I just bought a used 04 xc90 and want to use the spray seafoam. Where do I spray it in at.RCR wrote: 07 May 2011, 10:46 Uh you guys do know that they now make Seafoam in a spray can with a tube designed so you drop the pre bent tube into the intake just in front of the throttle body reattach the air tube and run it through don't you?? MUCH MUCH easier to use it that way and is more effective in cleaning the carbon off the pistons, chamber and valves done that way! Be sure you do a throttle plate and MAF clean also to get the full effect.
Seafoam In the tank is ok but I think there are better injector cleaners out there ( like the LUCAS) and I don't use it in the crankcase.
Mikele82
- Year and Model: XC70 04 + C30 T5 08
- Has thanked: 30 times
- Been thanked: 3 times
Can anyone post a picture on where exactly to put the new nozzle spray seafoam?RCR wrote: 07 May 2011, 10:46 Uh you guys do know that they now make Seafoam in a spray can with a tube designed so you drop the pre bent tube into the intake just in front of the throttle body reattach the air tube and run it through don't you?? MUCH MUCH easier to use it that way and is more effective in cleaning the carbon off the pistons, chamber and valves done that way! Be sure you do a throttle plate and MAF clean also to get the full effect.se.
maybe update the the intake seafoam procedure for the spray version?
MadDJacoby
- Year and Model: 2000 V40
The spray seafoam goes into your intake. On other cars I just snake it between intake hose & TB and spray it past the butterfly valve. I’m not sure how accessible that is on this car. I’m having intermittent P0016 exhaust over-advance codes which I thought was the timing at first. I’m figuring it’s either the solenoid or the gear but trying this fix first for sh*ts&gigs. Or who knows maybe I did the timing wrong and the code went away (i doubt that would happen right?)
Oh and I’ll update with the tube diameter when I figure it out.
I plan on investing in a chinese vida so when I do I’ll do a little write-up with my findings
JimBee
- Has thanked: 33 times
- Been thanked: 43 times
"I plan on investing in a chinese vida so when I do I’ll do a little write-up with my findings"
Watch out for the Chinese code readers. I have one bought several years ago that's almost brand new was only used on 3 cars to test it—after it failed to work on my 850. It didn't work on any of the other vehicles I tested in the local indy shop either. So it's junk. It's the MaxiDiag EU 702. I think at the time others on the forum were recommending it.
- 12 Replies
- 7571 Views
Last post by oragex
- 37 Replies
- 6730 Views
Last post by RickHaleParker
- 20 Replies
- 9606 Views
Last post by JimBee
- 594 Views
Last post by Ozark Lee
- 11 Replies
- 2817 Views
Last post by MarcM
