850 Control arm fiasco...little help please...
850 Control Arm Fiasco... Replacement Methods and Parts
- Been thanked: 504 times
Couple things:
1. To check control arm balljoint: jack the car up (don't remove the tire yet), grab the tire at 6 and 12 o'clock positions and rock in and out (toward and away from you).
FYI: rocking at 3 and 9 o'clock positions is for checking tierods.
These are just generic rules.
2. Yes, the procedure calls for new nuts and bolts. They are very cheap at dealer (a few dollars each). Get them ahead of time!!!
Use eeuroparts.com for PN.
Well, that's interesting because the tie rods on mine are fine- ball joints are shot and the movement is side to side (front to back on the car). eeuro unfortunately doesn't have the nut and bolt listed as mentioned- I know these guys...nut is $1.69 and bolt is $2.32 from the dealer- nut in stock bolt had to ordered- same thing on 10 calls. The nut must fit something else too...
The nut also fits the 2 bolts on steering knuckle where it "bites" onto the lower part of the strut.
Are you sure the PN for bolt you listed is correct?
control arms arent the part that fails but the ball joints and bushings that are mounted on the arm are. my car would pull to the right while braking, excessive tire wear.ecbsykes wrote:I don't mean to hijack this thread, but was wondering if someone could explain the symptoms of failing control arms. Is there a way to physically check it? What sort of while-driving symptoms would you encounter?
i just swapped control arms out and the ball joint end came out very easily with the use of pry bar. sorry to hear you had such a struggle
- 21 Replies
- 5822 Views
- 473 Views
Last post by MDK
- 13330 Views
Last post by MarcM
- 2965 Views
Last post by 800artfreed
- 25 Replies
- 5203 Views
