Hi all,
Third day of major work on my wife's '96 850 (197K). Got through timing belt, water pump, complete AC overhaul (it's cold!), and finally went after the control arms because it was eating tires. I thought I saved the easy one for last- no such luck.
Started on the right one and ran into a problem- got the bushing bolts out no problem then went at the bolt that holds the knuckle/ball joint. The nut loosened off bolt ok so I backed off the nut to the end and gave it a whack with the hammer thinking it would just come out the other side so that I could spread the knuckle and remove the rest of the control arm assy.it will not move - then tried to loosen the bolt side- still will not move. So far have broken two Craftsman 13mm sockets- needless to say the bolt is destroyed on both ends now and bent- these will be cut/drilled out tomorrow...the control arm is off as the bottom half of the ball joint is now out of the arm assy.
My question is this- is the male side of this bolt threaded into the knuckle?? (and then the nut closes it around the ball joint?) or should it just slide out. Secondly, what are the specs for this bolt 'cuz this one (and I suspect the left) are done.
Thanks in advance.
850 Control arm fiasco...little help please...
850 Control Arm Fiasco... Replacement Methods and Parts
- Been thanked: 504 times
Have a look at this:
http://volvospeed.com/Repair/cv_boot.html
The bolt is not threaded, it simply slides in and out.
The bolt is simply rusted in.
Re bolt spec; don't even think about hardware store bolt and nut, it is not strong enough to handle this job. Get this from dealer. You should have obtained new bolt and nut prior to doing this job.
Best is to:
- Get a propane torch that plumber uses to solder the plumbing and heat the knuckle for about 30 seconds to 60 seconds just to expand it.
- Another option is to use a ball joint separator to remove the bolt:
http://www.harborfreight.com/3-4-quarte ... 99849.html
Best is to:
Appreciate the great stuff you posted- CV's will be on the list sooner or later. That HF separator is cute but I would have to be able to move the bolt to get it underneath. Have an old school tie rod separator (that's how I broke the ball joint out of the control arm) it gave way before the knuckle would come out. Absolutely hate going near a Volvo dealer for any reason...looked at eeuro and FCP and neither list this nut/bolt...might have to give in unless somebody knows where else to get them- we live pretty far out and do almost everything by UPS, although eeuro is 7-8 miles and FCP about 45 minutes away- thanks.
Meanstreets
- Year and Model: 1997 855 T5 Wagon
I replaced the control arm about a month ago. Like you said, it was a chore to get the bolt out. Lots of WD-40 and time to sit. Then tapped it out with a hammer before I could finally get the ball joint free.
FlyingVolvo
- Year and Model: 2000 V70XC
- Has thanked: 51 times
- Been thanked: 74 times
I don't mean to hijack this thread, but was wondering if someone could explain the symptoms of failing control arms. Is there a way to physically check it? What sort of while-driving symptoms would you encounter?
2000 V70XC - 340,000 miles
2023 V60 T8 PE
2023 V60 T8 PE
JDS60R
- Been thanked: 3 times
Can you drill out the bolt from the side with the bolt head. Once the head is seperated from the rest of the bolt you can drive it out with a punch and hammer.
Or just use the old orange wrench and heat up the nut until it turns off. Keep in mind that if someone used red loctite it will not let go until 600 degrees. You can get that with a heat gun but a torch is faster.
Retired
Since I didn't have the parts I took a break yesterday. So, this morning called every Volvo dealer in CT & MA- everyone has the nut but not the bolt- UGH. As CN90 said, GET THESE BEFORE ATTEMPTING THIS FIX! Or you will have a crippled car on your lift like me...P/N's Nut- 987891 Bolt- 9881185. Might as well go to the beach today.
vjaneczko
- Year and Model: 2006 S60R
- Been thanked: 7 times
1997 855 GLT - R.I.P.
2006 S60R - For ME!
2006 S60R - For ME!
- 21 Replies
- 5831 Views
- 475 Views
Last post by MDK
- 13345 Views
Last post by MarcM
- 2977 Views
Last post by 800artfreed
- 25 Replies
- 5231 Views
