I have known various sensors fail and not set a code. The OBD on the early cars was basic unlike the all singing, all dancing OBD11, which can also miss a fault.
Bill.
1991 740 non turbo starts hard, bogs, sputters, front-fires
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- billofdurham
Thank you for the update.
Bill.
Bill.
Previously:
Previously:
The OBD indicates there's a problem with the air temp sensor, 91 740. When I try to remove the sensor, which is a somewhat tight fit for large arm/hand, the plastic case comes off but the wires are still in the sensor mount screwed into the crankcase. How do you get the wires out?
resurrecting ancient thread to thank op for excellent description of problem.
I'm dealing with EXACTLY the same problem and I am very glad to see I'm heading in the right direction. Good descriptions make for good reference materials.
I worked my way through this problem every Sunday afternoon for 2 months, came to a similar conclusion. FPR, fuel pump, bad gas...and now I will check crank sensor too.
should have just checked the interweb in the first place, could've saved some weekends.
thanks,
Tim
thanks,
Tim
Im having similar problems. Diagnostic box says MAS Meter and O2 senser. Went to junk yard, got an mas meter from a 740 Bosch 016 but when I got home the meters have same part number but they look different inside. Original Volvo ( In my car ) has a what it looks like a saxophone leed inside, and the meter I got from the j/y looks like it has 2 different size fillaments, one big one smaller. I wonder what the difference is.
- 93Regina
- Year and Model: 93:240/940
- Been thanked: 65 times
Most interesting...fuel pump not up to specs would cause hard starts, etc., but, getting a 3-1-1 code that ends up being a crankshaft sensor issue, is most puzzling.dnarby wrote:25 Jun 2010 - Disconnecting the air temp sensor didn't change anything (but it did register 1-2-2 on the fuel self diagnostic, which is good to know). It also threw 3-1-1 on the fuel diagnostic, but my speedometer is intermittent (I use my GPS for a speedo). Ignition diagnostics threw 1-1-1.
Solution - 23 May 2011 - Looks like the problem was a crankshaft sensor... AND the fuel pump.
I've got a recent 3-1-1 code on a 1993-944, but I renewed CPS last year....and vehicle runs fine, including cruise control.
I'll try installing an used Bosch CPS, and see what happens.
- 1283 Views
Last post by mountaincarjunkie
- 11 Replies
- 2321 Views
Last post by erikv11
- 22 Replies
- 2470 Views
Last post by Holiday
- 3632 Views
Last post by RickHaleParker
- 590 Views
Last post by doublebug
