99 s80 T6 will not start
Ok, here’s an update for you. I used a meter to check if I was getting power at starter. That was good then I pulled the wire off the solenoid that comes from the key switch to see if it was ting power when I turned the key that was also good. But I did notice that it seemed to pull off fairly easy. I crimped the spade connector a little so it would be a tighter fit and reconnected it. It has been 4 days now and no more problems.
KevinsS80T
- Year and Model: 99 S80T
"start prevented try again" display / err message in on board display. So, FPatti88.... the spade connector appeared loose and you crimped it and you have had no further prob till this date 7/2011 I assume...if you get this post please reply if you have not had any further problems... thank you in advance...
Kevin....
Kevin....
dcarlson12
- Year and Model: 1997 850 T5
- Been thanked: 2 times
Could fpatti88 possibly upload a photo of where the spade connector is located or possibly a VADIS page?
KevinsS80T
dcarlson12 wrote:Could fpatti88 possibly upload a photo of where the spade connector is located or possibly a VADIS page?
the same think crossed my mind.... if any could contact fPatti... that'd be so great....
KevinsS80T
Well I ran out options.... My 99 s80 continued to not start at the worst times... still showing "start prevented try again"... However I did find a Volvo dealer just 40 minutes away that ran a diagnostic and told me everything else that the car would need along with it needing a new ignition immobilizer on the antenna it cost 59us dollars plus labor 90us for the hour... it took approximately an hour an a half and the job was done.... I will use this dealership again.... the service was great.... they were professional and courteous.... Maxwell Volvo; Burlington, NC....
- 1442 Views
Last post by renegade343
- 1106 Views
Last post by Kram
- 1015 Views
Last post by draser
- 1283 Views
Last post by SuperHerman
- 461 Views
Last post by teachme
