1999 s70 t5.
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
s70-expolice2010
Year and Model: volvo s70 t5 1999
Re: 1999 s70 t5.
Post by s70-expolice2010 »
it was the c02 sensor bank1 sensor 1!!!!
s70-expolice2010
hi just an update,i have a volvo s70 t5 ex police,now been remapped to 280 bhp,induction filter cold air feed,full stain less cat by pass, turbo tweek by the actuator rod,big evo 9 intercooler running at 15 psi.has any one put a mbc on the 1999 t5,thanks steve...
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
MBC's will not work on a 1999 - the computer corrects the boost level as soon as it notices that it is increased. Re-mapping like you did already is about the only way to get more boost out of these models.
'98 S70 T5
2016 Chevy Cruze Premier
s70-expolice2010
hi ya pal thanks for the reply,can it be remapped to 304 bhp with out the rolling road,as my pal does the ecu remap for £150,thanks steve.
jblackburn
It probably can - but the idea to of the rolling road is to tune it so that the power is across the entire rev range, rather than just at one end - high or low.
If you still plan on using the automatic, I would not go much over 300 hp, as it just can't handle much more power than that.
'98 S70 T5
s70-expolice2010
yeah, i think its near to 300hp,and it the manual box.. now the intercooler has give it a big boost!!,and i have give the actuator 2 full turns now running at 15 psi like you say i think 300 hp is enough..lol..
